The standard Raspberry Pi install/update script says it will work on, "any Debian-based operating system":
https://nodered.org/docs/getting-started/raspberrypi
Indeed, it does seem to have got Node-RED starting on my Rock 4C+ running Debian Bullseye:
When prompted to "install the Pi-specific nodes?", I answered No.
Was that correct - would these "Pi-specific nodes" be expected to work on the Rock 4C+ ?
On my actual Raspberry Pi, I have:
The ADS1x15 I added manually, but I presume the others are those "Pi-specific nodes"?
I would not expect the GPIO nodes to work unless there is a python package called RPi.GPIO installed... - In reality you can install the extra nodes if you like - but they just won't work and take up that menu space... no harm either way - and it would let you edit flows from the Pi version if you needed to.
Thanks.
Looks like the equivalent on Rock is pyRock:
https://wiki.radxa.com/News/2014/10/pyRock-python-gpio-library
Am I correct that the "Pi-specific nodes" mentioned by the script are just the 4 nodes rpi-gpio-in, rpi-gpio-out, rpi-mouse, and rpi-keyboard ?
Those are the ones that "won't work" - The full list we install to make life easier is
node-red-node-pi-gpio@latest node-red-node-random@latest node-red-node-ping@latest node-red-contrib-play-audio@latest node-red-node-smooth@latest node-red-node-serialport@latest node-red-contrib-buffer-parser@latest
