I all, I'm writing a node-red code with s7comm node. I would like pass the signal and path message from a injection instead of set it in the "connection parameter"
this because I would create a general code with could work with many machines instead of customize parameters for each machine.
can someone help me?
Unfortunately, it is not possible to set the connection parameters from a message because the node you are using is not supporting it.
There is a workaround which involves the use of the Admin API directly from node-red to dynamically change the connection parameters of the node.
Many thanks. Do you have example? I never set admin api
