Input of endpoint and variables (database) via dashboard - node-red-contrib-s7
Hello all,
is there a possibility to type in the endpoint ip adres and the variables through the dashboard? I already create a variable for the ip adres and variables, but i cant find a solution to connect together.
@machadotiago maybe you have a solution?
thank you all in advance...
Greetz Murat
Hello @mcom, unfortunately that is not possible. The only way is to change the flow file. You can do that by using the admin API of node-red (more details here: Admin API : Node-RED)
Hey @machadotiago ,
sorry for my late reply. In the meantime i have made some trial with influxDB. At first happy new year and best wishes !
I have made altough some trial with the REST API of NODE-RED. I could replace with the /flow/global the configuration. But somehow this request kill my other config for dashbord etc.. Do you have an Idea, how can replace only the S7 config? Or should i start another Topic?
Greetz Murat
you could use npm nodes7. I've posted an example of dynamic addressing, maybe this might come to use: Siemens reading from PLC with nodeS7 npm
Hello @KarolisL ,
this looks interesting, I will try it out and let you know!!! Thanks in advance for your attention
