Dynamic s7 endpoint configuration
Hi to everyone!
I'm starting with node-red programming and I need some help with my current project.
I already have connected a s7 1200 Siemens PLC to node-red to read/write the process information.
The question I have is: there is a way to configure the s7 endpoint from a graphic UI or sql database? Like the IP address, the current slot or the DB and offset where a data is located.
Thanks in advance for the help.
Eros Baixauli
