Same subflow, different happening on different machines
Sorry folks:
..... I'm ba-ack.....!
I've recently been working on a subflow and made a lot of silly mistakes.
(I'll cop that.)
So entered the command correctly and all should be good - yeah?
:frowning:
Nah.
One machine it works, the other machine, doesn't.
Details:
NR 3.0.2
node -v 16.20.02
both machines.
So what's going on?
The error I get is:
{"message":"Invalid JSONata expression: Cannot read properties of undefined (reading 'startsWith')","source":{"id":"da42a7e9064de621","type":"change","name":"#1","count":1}}
What throws me is:
It is a change node.
(code)
        "id": "27d2dd9a875ab1a5",
        "type": "change",
        "z": "94cf2ea396e5b6f6",
        "name": "#1",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "DN",
                "tot": "env"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "topic & '/cmnd/power' & $env(power)",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1080,
        "y": 160,
There's no startingwith( ) in there.
So I'm guessing it is a syntactical problem.
For the sake of sharing:
The code - no GUI stuff or MQTT nodes.
But the guts of the code:
[{"id":"94cf2ea396e5b6f6","type":"subflow","name":"MQTT Button Toggle","info":"# 2023 02 08\nAdded status text to icon to \nshow status of device.\n\n# 2023 01 25\nControl MQTT devices (power points)\nwith this node.\n\n`Button` node MUST have `topic` set to include\nthe device's name.  eg: `A1/button`\nand the payload MUST be `X`\n\nSet the `Device Name` to (eg) `A1` to\ncontrol `A1` device.\n\n`payload` must be `X` to TOGGLE output\n\nsend `ON` to force ON state\n\nsend `OFF` to force OFF state\n\nsend `RELOAD` to force button to\ndisplay current state.\n(added 2024 01 28)\n\n","category":"","in":[{"x":100,"y":160,"wires":[{"id":"0cc9b2fa9b2af8df"}]}],"out":[{"x":1280,"y":220,"wires":[{"id":"66fb54e88f4acb8d","port":0}]},{"x":1250,"y":160,"wires":[{"id":"27d2dd9a875ab1a5","port":0}]}],"env":[{"name":"DN","type":"str","value":"","ui":{"label":{"en-US":"Device Name"},"type":"input","opts":{"types":["str"]}}},{"name":"power","type":"num","value":"","ui":{"label":{"en-US":"Output"},"type":"input","opts":{"types":["num"]}}}],"meta":{},"color":"#DDAA99","inputLabels":["MQTT (tele and LWT) and button input"],"outputLabels":["Back to `button` input","MQTT output"],"status":{"x":1200,"y":270,"wires":[{"id":"45a85f7621f5c28f","port":0}]}},{"id":"541720ad73579447","type":"switch","z":"94cf2ea396e5b6f6","name":"what message?","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"/stat/POWER","vt":"str"},{"t":"cont","v":"/tele/LWT","vt":"str"},{"t":"cont","v":"button","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":315,"y":160,"wires":[["61843ca1684f9f9d"],["4788b5265af1d45a"],["5b8cd9fe254ea8d1"]],"l":false},{"id":"61843ca1684f9f9d","type":"delay","z":"94cf2ea396e5b6f6","name":"Delay","pauseType":"delay","timeout":"200","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":460,"y":80,"wires":[["bdb2c46daf62b36f"]]},{"id":"6d4704f6fc9b98be","type":"change","z":"94cf2ea396e5b6f6","name":"RESET","rules":[{"t":"set","p":"payload","pt":"msg","to":"RESET","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":120,"wires":[["bdb2c46daf62b36f"]]},{"id":"4788b5265af1d45a","type":"switch","z":"94cf2ea396e5b6f6","name":"LWT","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Online","vt":"str"},{"t":"eq","v":"Offline","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":460,"y":160,"wires":[["6d4704f6fc9b98be","bc2aabd04561d534"],["6a82c12953657965"]]},{"id":"6a82c12953657965","type":"function","z":"94cf2ea396e5b6f6","name":"BAN","func":"msg = {icon: '<font color = \"red\"><i class=\"fa fa-ban fa-3x\"></i></font>'};\nreturn msg;","outputs":1,"noerr":0,"x":460,"y":200,"wires":[["8dc8a0dd2b669ae3","704ae850657c9724"]]},{"id":"bc2aabd04561d534","type":"change","z":"94cf2ea396e5b6f6","name":"Enable","rules":[{"t":"set","p":"enabled","pt":"msg","to":"true","tot":"bool"},{"t":"set","p":"ARLEC-1","pt":"flow","to":"ONLINE","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":160,"wires":[["66fb54e88f4acb8d"]]},{"id":"bdb2c46daf62b36f","type":"function","z":"94cf2ea396e5b6f6","name":"Set state","func":"let device = msg.topic.split(\"/\");\nnode.warn(\"Device \" + device[0]);\nnode.warn(\"Payload \" + msg.payload);\n\nif (msg.payload == \"RESET\")\n{\n    let state = context.get(device[0]);\n    if (state === 0)\n    {\n        //\n        msg= {\"icon\": '<font color = \"red\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>',\"background\":\"black\"};\n        return msg;\n    }\n    //\n}\nif (msg.payload == \"ON\")\n{\n    msg = { \"icon\": '<font color = \"lime\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"background\": \"black\" };\n    context.set(\"STATE\",1);\n    context.set(device[0],1);\n} else\n{\n    msg = { \"icon\": '<font color = \"red\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>', \"background\": \"black\" };\n    context.set(\"STATE\",0);\n    context.set(device[0], 1);\n}\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":660,"y":120,"wires":[["66fb54e88f4acb8d"]]},{"id":"8dc8a0dd2b669ae3","type":"change","z":"94cf2ea396e5b6f6","name":"Disable","rules":[{"t":"set","p":"enabled","pt":"msg","to":"false","tot":"bool"},{"t":"set","p":"ARLEC-1","pt":"flow","to":"OFFLINE","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":200,"wires":[["66fb54e88f4acb8d"]]},{"id":"5b8cd9fe254ea8d1","type":"function","z":"94cf2ea396e5b6f6","name":"Button control","func":"let msg1 = {};\n\nlet x = msg.payload;\nlet counter = context.get(\"counter\") || 0;\nif (x == \"X\")\n{\n    counter = (counter + 1) % 2;\n    context.set(\"counter\",counter);\n    if (counter === 0)\n    {\n        //\n        msg.payload = \"OFF\";\n        msg1 = {\"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>',\"background\":\"black\"};\n    } else\n    {\n        //\n        msg.payload = \"ON\";\n        msg1 = {\"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>',\"backgound\":\"black\"};\n    }\n}\nif (x == \"RELOAD\")\n{\n    //  Reload/display status.\n    if (counter == 0)\n    {\n        //  OFF\n        x = \"OFF\";\n        msg.payload = \"OFF\";\n        msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>', \"background\": \"black\" };\n    }\n    else\n    if (counter == 1)\n    {\n        //  ON\n        x = \"ON\";\n        msg.payload = \"ON\";\n        msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    }\n}\n\n\nif (x == \"ON\")\n{\n    //  Force power ON\n    msg.payload = \"ON\";\n    msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    context.set(\"counter\",1);\n}\nif (x == \"OFF\")\n{\n    //  Force power OFF\n    msg.payload = \"OFF\";\n    msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    context.set(\"counter\",0);\n}\n\nreturn [msg,msg1];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":870,"y":120,"wires":[["4f29a481b6f0d0e3","0ae8f43ccf9a1016"],["66fb54e88f4acb8d"]]},{"id":"4f29a481b6f0d0e3","type":"delay","z":"94cf2ea396e5b6f6","name":"Delay","pauseType":"delay","timeout":"100","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":1080,"y":120,"wires":[["27d2dd9a875ab1a5"]]},{"id":"27d2dd9a875ab1a5","type":"change","z":"94cf2ea396e5b6f6","name":"#1","rules":[{"t":"set","p":"topic","pt":"msg","to":"DN","tot":"env"},{"t":"set","p":"topic","pt":"msg","to":"topic & '/cmnd/power' & $env(power)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":160,"wires":[[]]},{"id":"7207fbe19cc07923","type":"switch","z":"94cf2ea396e5b6f6","name":"Only for this device","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"DN","vt":"env"},{"t":"eq","v":"MASTER","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":255,"y":160,"wires":[["541720ad73579447"],["6a82c12953657965"]],"l":false},{"id":"0ae8f43ccf9a1016","type":"function","z":"94cf2ea396e5b6f6","name":"Identify","func":"let dev = env.get(\"DN\") + \" \" + env.get(\"power\");\nlet status = msg.payload;\n\nnode.status(dev + \" \" + status);","outputs":1,"noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\nnode.status(env.get(\"DN\"));\n","finalize":"","libs":[],"x":660,"y":270,"wires":[[]]},{"id":"45a85f7621f5c28f","type":"status","z":"94cf2ea396e5b6f6","name":"","scope":["0ae8f43ccf9a1016"],"x":1070,"y":270,"wires":[[]]},{"id":"704ae850657c9724","type":"change","z":"94cf2ea396e5b6f6","name":"Wipe status when unplugged","rules":[{"t":"set","p":"payload","pt":"msg","to":" ","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":425,"y":270,"wires":[["0ae8f43ccf9a1016"]],"l":false},{"id":"0cc9b2fa9b2af8df","type":"switch","z":"94cf2ea396e5b6f6","name":"Reload?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"RELOAD","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":175,"y":160,"wires":[["5b8cd9fe254ea8d1"],["7207fbe19cc07923"]],"l":false},{"id":"66fb54e88f4acb8d","type":"junction","z":"94cf2ea396e5b6f6","x":800,"y":220,"wires":[[]]},{"id":"e72bae9952eddd60","type":"inject","z":"26262ba1.62dcbc","name":"Button","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"A5/button","payload":"X","payloadType":"str","x":1530,"y":4730,"wires":[["76117c24ef0f5cf3"]]},{"id":"76117c24ef0f5cf3","type":"link out","z":"26262ba1.62dcbc","name":"Button","mode":"link","links":["bfdb3c588016491b"],"x":1625,"y":4770,"wires":[]},{"id":"bfdb3c588016491b","type":"link in","z":"26262ba1.62dcbc","name":"Button","links":["76117c24ef0f5cf3"],"x":1035,"y":4840,"wires":[["7ebd5a2bb58fd95c"]]},{"id":"9508b1d704f5549d","type":"subflow:94cf2ea396e5b6f6","z":"26262ba1.62dcbc","name":"","env":[{"name":"DN","value":"A5","type":"str"},{"name":"power","value":"1","type":"num"},{"name":"Device name","value":"A1","type":"str"}],"x":1260,"y":4800,"wires":[["099a494a54542f2d","3b578a30c600e702"],["e87f2ab9ebfdeb7f"]]}]
On machine 1 I press the inject and the subflow works.
On machine 2 I press the inject and get the error.
Note:
the node-status changes on the faulty machine though. So all is good to there.
P.P.S
If I change that change node to this:
        "type": "change",
        "name": "#1",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "DN",
                "tot": "env"
                "t": "set",
                "p": "power",
                "pt": "msg",
                "to": "power",
                "tot": "env"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "topic & '/cmnd/power' & power",
                "tot": "jsonata"
                "t": "delete",
                "p": "power",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1080,
        "y": 160,
No error.
P.P.P.S.
Just checked.
the change node on both machines: same version.
3.0.2
Sorry folks, I seem to be missing something.
Just a thought, does $env(power) exist on failing machine?
Good question.
Alas,
Yes.
Out of interest, does the flow work for you?
Your test flow appears to missing some vital elements
I don't use JSONata much, but I think it should be $env('power')
Also you should upgrade to the latest version of node-red.
Oh, thanks.
Interesting.
Hang on.
New code/flow.
This is the working subflow code.
[{"id":"94cf2ea396e5b6f6","type":"subflow","name":"MQTT Button Toggle","info":"# 2023 02 08\nAdded status text to icon to \nshow status of device.\n\n# 2023 01 25\nControl MQTT devices (power points)\nwith this node.\n\n`Button` node MUST have `topic` set to include\nthe device's name.  eg: `A1/button`\nand the payload MUST be `X`\n\nSet the `Device Name` to (eg) `A1` to\ncontrol `A1` device.\n\n`payload` must be `X` to TOGGLE output\n\nsend `ON` to force ON state\n\nsend `OFF` to force OFF state\n\nsend `RELOAD` to force button to\ndisplay current state.\n(added 2024 01 28)\n\n","category":"","in":[{"x":100,"y":160,"wires":[{"id":"0cc9b2fa9b2af8df"}]}],"out":[{"x":1280,"y":220,"wires":[{"id":"66fb54e88f4acb8d","port":0}]},{"x":1250,"y":160,"wires":[{"id":"27d2dd9a875ab1a5","port":0}]}],"env":[{"name":"DN","type":"str","value":"","ui":{"label":{"en-US":"Device Name"},"type":"input","opts":{"types":["str"]}}},{"name":"power","type":"num","value":"","ui":{"label":{"en-US":"Output"},"type":"input","opts":{"types":["num"]}}}],"meta":{},"color":"#DDAA99","inputLabels":["MQTT (tele and LWT) and button input"],"outputLabels":["Back to `button` input","MQTT output"],"status":{"x":1200,"y":270,"wires":[{"id":"45a85f7621f5c28f","port":0}]}},{"id":"541720ad73579447","type":"switch","z":"94cf2ea396e5b6f6","name":"what message?","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"/stat/POWER","vt":"str"},{"t":"cont","v":"/tele/LWT","vt":"str"},{"t":"cont","v":"button","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":315,"y":160,"wires":[["61843ca1684f9f9d"],["4788b5265af1d45a"],["5b8cd9fe254ea8d1"]],"l":false},{"id":"61843ca1684f9f9d","type":"delay","z":"94cf2ea396e5b6f6","name":"Delay","pauseType":"delay","timeout":"200","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":460,"y":80,"wires":[["bdb2c46daf62b36f"]]},{"id":"6d4704f6fc9b98be","type":"change","z":"94cf2ea396e5b6f6","name":"RESET","rules":[{"t":"set","p":"payload","pt":"msg","to":"RESET","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":120,"wires":[["bdb2c46daf62b36f"]]},{"id":"4788b5265af1d45a","type":"switch","z":"94cf2ea396e5b6f6","name":"LWT","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Online","vt":"str"},{"t":"eq","v":"Offline","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":460,"y":160,"wires":[["6d4704f6fc9b98be","bc2aabd04561d534"],["6a82c12953657965"]]},{"id":"6a82c12953657965","type":"function","z":"94cf2ea396e5b6f6","name":"BAN","func":"msg = {icon: '<font color = \"red\"><i class=\"fa fa-ban fa-3x\"></i></font>'};\nreturn msg;","outputs":1,"noerr":0,"x":460,"y":200,"wires":[["8dc8a0dd2b669ae3","704ae850657c9724"]]},{"id":"bc2aabd04561d534","type":"change","z":"94cf2ea396e5b6f6","name":"Enable","rules":[{"t":"set","p":"enabled","pt":"msg","to":"true","tot":"bool"},{"t":"set","p":"ARLEC-1","pt":"flow","to":"ONLINE","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":160,"wires":[["66fb54e88f4acb8d"]]},{"id":"bdb2c46daf62b36f","type":"function","z":"94cf2ea396e5b6f6","name":"Set state","func":"let device = msg.topic.split(\"/\");\nnode.warn(\"Device \" + device[0]);\nnode.warn(\"Payload \" + msg.payload);\n\nif (msg.payload == \"RESET\")\n{\n    let state = context.get(device[0]);\n    if (state === 0)\n    {\n        //\n        msg= {\"icon\": '<font color = \"red\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>',\"background\":\"black\"};\n        return msg;\n    }\n    //\n}\nif (msg.payload == \"ON\")\n{\n    msg = { \"icon\": '<font color = \"lime\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"background\": \"black\" };\n    context.set(\"STATE\",1);\n    context.set(device[0],1);\n} else\n{\n    msg = { \"icon\": '<font color = \"red\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>', \"background\": \"black\" };\n    context.set(\"STATE\",0);\n    context.set(device[0], 1);\n}\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":660,"y":120,"wires":[["66fb54e88f4acb8d"]]},{"id":"8dc8a0dd2b669ae3","type":"change","z":"94cf2ea396e5b6f6","name":"Disable","rules":[{"t":"set","p":"enabled","pt":"msg","to":"false","tot":"bool"},{"t":"set","p":"ARLEC-1","pt":"flow","to":"OFFLINE","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":200,"wires":[["66fb54e88f4acb8d"]]},{"id":"5b8cd9fe254ea8d1","type":"function","z":"94cf2ea396e5b6f6","name":"Button control","func":"let msg1 = {};\n\nlet x = msg.payload;\nlet counter = context.get(\"counter\") || 0;\nif (x == \"X\")\n{\n    counter = (counter + 1) % 2;\n    context.set(\"counter\",counter);\n    if (counter === 0)\n    {\n        //\n        msg.payload = \"OFF\";\n        msg1 = {\"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>',\"background\":\"black\"};\n    } else\n    {\n        //\n        msg.payload = \"ON\";\n        msg1 = {\"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>',\"backgound\":\"black\"};\n    }\n}\nif (x == \"RELOAD\")\n{\n    //  Reload/display status.\n    if (counter == 0)\n    {\n        //  OFF\n        x = \"OFF\";\n        msg.payload = \"OFF\";\n        msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>', \"background\": \"black\" };\n    }\n    else\n    if (counter == 1)\n    {\n        //  ON\n        x = \"ON\";\n        msg.payload = \"ON\";\n        msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    }\n}\n\n\nif (x == \"ON\")\n{\n    //  Force power ON\n    msg.payload = \"ON\";\n    msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    context.set(\"counter\",1);\n}\nif (x == \"OFF\")\n{\n    //  Force power OFF\n    msg.payload = \"OFF\";\n    msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    context.set(\"counter\",0);\n}\n\nreturn [msg,msg1];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":870,"y":120,"wires":[["4f29a481b6f0d0e3","0ae8f43ccf9a1016"],["66fb54e88f4acb8d"]]},{"id":"4f29a481b6f0d0e3","type":"delay","z":"94cf2ea396e5b6f6","name":"Delay","pauseType":"delay","timeout":"100","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":1080,"y":120,"wires":[["27d2dd9a875ab1a5"]]},{"id":"27d2dd9a875ab1a5","type":"change","z":"94cf2ea396e5b6f6","name":"#1","rules":[{"t":"set","p":"topic","pt":"msg","to":"DN","tot":"env"},{"t":"set","p":"power","pt":"msg","to":"power","tot":"env"},{"t":"set","p":"topic","pt":"msg","to":"topic & '/cmnd/power' & power","tot":"jsonata"},{"t":"delete","p":"power","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":160,"wires":[[]]},{"id":"7207fbe19cc07923","type":"switch","z":"94cf2ea396e5b6f6","name":"Only for this device","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"DN","vt":"env"},{"t":"eq","v":"MASTER","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":255,"y":160,"wires":[["541720ad73579447"],["6a82c12953657965"]],"l":false},{"id":"0ae8f43ccf9a1016","type":"function","z":"94cf2ea396e5b6f6","name":"Identify","func":"let dev = env.get(\"DN\") + \" \" + env.get(\"power\");\nlet status = msg.payload;\n\nnode.status(dev + \" \" + status);","outputs":1,"noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\nnode.status(env.get(\"DN\"));\n","finalize":"","libs":[],"x":660,"y":270,"wires":[[]]},{"id":"45a85f7621f5c28f","type":"status","z":"94cf2ea396e5b6f6","name":"","scope":["0ae8f43ccf9a1016"],"x":1070,"y":270,"wires":[[]]},{"id":"704ae850657c9724","type":"change","z":"94cf2ea396e5b6f6","name":"Wipe status when unplugged","rules":[{"t":"set","p":"payload","pt":"msg","to":" ","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":425,"y":270,"wires":[["0ae8f43ccf9a1016"]],"l":false},{"id":"0cc9b2fa9b2af8df","type":"switch","z":"94cf2ea396e5b6f6","name":"Reload?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"RELOAD","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":175,"y":160,"wires":[["5b8cd9fe254ea8d1"],["7207fbe19cc07923"]],"l":false},{"id":"66fb54e88f4acb8d","type":"junction","z":"94cf2ea396e5b6f6","x":800,"y":220,"wires":[[]]},{"id":"855284d6a5fc170b","type":"link in","z":"6dd5ca4d.d1958c","g":"9f60476ecbac25b5","name":"Button","links":["c2f5a62f6628cf5f","fbd3f3b5b44d5dbb"],"x":4065,"y":4040,"wires":[["8cf1535e17381a6a"]]},{"id":"8cf1535e17381a6a","type":"subflow:94cf2ea396e5b6f6","z":"6dd5ca4d.d1958c","g":"9f60476ecbac25b5","name":"","env":[{"name":"DN","value":"A8","type":"str"},{"name":"power","value":"1","type":"num"},{"name":"Device name","value":"A1","type":"str"}],"x":4210,"y":4000,"wires":[["ec6fb6fef082bdb3"],["d7a4eeb602615312","4acfea6a575732bb"]]},{"id":"fbd3f3b5b44d5dbb","type":"link out","z":"6dd5ca4d.d1958c","g":"9f60476ecbac25b5","name":"link out 49","mode":"link","links":["855284d6a5fc170b"],"x":4515,"y":3970,"wires":[]},{"id":"456bf6dc69b793ae","type":"inject","z":"6dd5ca4d.d1958c","g":"9f60476ecbac25b5","name":"Button","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"A8/button","payload":"X","payloadType":"str","x":4420,"y":3930,"wires":[["fbd3f3b5b44d5dbb"]]}]
Or, connect the link-in node to the input of the subflow.
Don't know how that connection got missed.
Update:
This is with the code which causes errors on the other machine.
It should work, but doesn't.
[{"id":"94cf2ea396e5b6f6","type":"subflow","name":"MQTT Button Toggle","info":"# 2023 02 08\nAdded status text to icon to \nshow status of device.\n\n# 2023 01 25\nControl MQTT devices (power points)\nwith this node.\n\n`Button` node MUST have `topic` set to include\nthe device's name.  eg: `A1/button`\nand the payload MUST be `X`\n\nSet the `Device Name` to (eg) `A1` to\ncontrol `A1` device.\n\n`payload` must be `X` to TOGGLE output\n\nsend `ON` to force ON state\n\nsend `OFF` to force OFF state\n\nsend `RELOAD` to force button to\ndisplay current state.\n(added 2024 01 28)\n\n","category":"","in":[{"x":100,"y":160,"wires":[{"id":"0cc9b2fa9b2af8df"}]}],"out":[{"x":1280,"y":220,"wires":[{"id":"66fb54e88f4acb8d","port":0}]},{"x":1250,"y":160,"wires":[{"id":"27d2dd9a875ab1a5","port":0}]}],"env":[{"name":"DN","type":"str","value":"","ui":{"label":{"en-US":"Device Name"},"type":"input","opts":{"types":["str"]}}},{"name":"power","type":"num","value":"","ui":{"label":{"en-US":"Output"},"type":"input","opts":{"types":["num"]}}}],"meta":{},"color":"#DDAA99","inputLabels":["MQTT (tele and LWT) and button input"],"outputLabels":["Back to `button` input","MQTT output"],"status":{"x":1200,"y":270,"wires":[{"id":"45a85f7621f5c28f","port":0}]}},{"id":"541720ad73579447","type":"switch","z":"94cf2ea396e5b6f6","name":"what message?","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"/stat/POWER","vt":"str"},{"t":"cont","v":"/tele/LWT","vt":"str"},{"t":"cont","v":"button","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":315,"y":160,"wires":[["61843ca1684f9f9d"],["4788b5265af1d45a"],["5b8cd9fe254ea8d1"]],"l":false},{"id":"61843ca1684f9f9d","type":"delay","z":"94cf2ea396e5b6f6","name":"Delay","pauseType":"delay","timeout":"200","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":460,"y":80,"wires":[["bdb2c46daf62b36f"]]},{"id":"6d4704f6fc9b98be","type":"change","z":"94cf2ea396e5b6f6","name":"RESET","rules":[{"t":"set","p":"payload","pt":"msg","to":"RESET","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":120,"wires":[["bdb2c46daf62b36f"]]},{"id":"4788b5265af1d45a","type":"switch","z":"94cf2ea396e5b6f6","name":"LWT","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Online","vt":"str"},{"t":"eq","v":"Offline","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":460,"y":160,"wires":[["6d4704f6fc9b98be","bc2aabd04561d534"],["6a82c12953657965"]]},{"id":"6a82c12953657965","type":"function","z":"94cf2ea396e5b6f6","name":"BAN","func":"msg = {icon: '<font color = \"red\"><i class=\"fa fa-ban fa-3x\"></i></font>'};\nreturn msg;","outputs":1,"noerr":0,"x":460,"y":200,"wires":[["8dc8a0dd2b669ae3","704ae850657c9724"]]},{"id":"bc2aabd04561d534","type":"change","z":"94cf2ea396e5b6f6","name":"Enable","rules":[{"t":"set","p":"enabled","pt":"msg","to":"true","tot":"bool"},{"t":"set","p":"ARLEC-1","pt":"flow","to":"ONLINE","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":160,"wires":[["66fb54e88f4acb8d"]]},{"id":"bdb2c46daf62b36f","type":"function","z":"94cf2ea396e5b6f6","name":"Set state","func":"let device = msg.topic.split(\"/\");\nnode.warn(\"Device \" + device[0]);\nnode.warn(\"Payload \" + msg.payload);\n\nif (msg.payload == \"RESET\")\n{\n    let state = context.get(device[0]);\n    if (state === 0)\n    {\n        //\n        msg= {\"icon\": '<font color = \"red\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>',\"background\":\"black\"};\n        return msg;\n    }\n    //\n}\nif (msg.payload == \"ON\")\n{\n    msg = { \"icon\": '<font color = \"lime\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"background\": \"black\" };\n    context.set(\"STATE\",1);\n    context.set(device[0],1);\n} else\n{\n    msg = { \"icon\": '<font color = \"red\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>', \"background\": \"black\" };\n    context.set(\"STATE\",0);\n    context.set(device[0], 1);\n}\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":660,"y":120,"wires":[["66fb54e88f4acb8d"]]},{"id":"8dc8a0dd2b669ae3","type":"change","z":"94cf2ea396e5b6f6","name":"Disable","rules":[{"t":"set","p":"enabled","pt":"msg","to":"false","tot":"bool"},{"t":"set","p":"ARLEC-1","pt":"flow","to":"OFFLINE","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":200,"wires":[["66fb54e88f4acb8d"]]},{"id":"5b8cd9fe254ea8d1","type":"function","z":"94cf2ea396e5b6f6","name":"Button control","func":"let msg1 = {};\n\nlet x = msg.payload;\nlet counter = context.get(\"counter\") || 0;\nif (x == \"X\")\n{\n    counter = (counter + 1) % 2;\n    context.set(\"counter\",counter);\n    if (counter === 0)\n    {\n        //\n        msg.payload = \"OFF\";\n        msg1 = {\"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>',\"background\":\"black\"};\n    } else\n    {\n        //\n        msg.payload = \"ON\";\n        msg1 = {\"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>',\"backgound\":\"black\"};\n    }\n}\nif (x == \"RELOAD\")\n{\n    //  Reload/display status.\n    if (counter == 0)\n    {\n        //  OFF\n        x = \"OFF\";\n        msg.payload = \"OFF\";\n        msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>', \"background\": \"black\" };\n    }\n    else\n    if (counter == 1)\n    {\n        //  ON\n        x = \"ON\";\n        msg.payload = \"ON\";\n        msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    }\n}\n\n\nif (x == \"ON\")\n{\n    //  Force power ON\n    msg.payload = \"ON\";\n    msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    context.set(\"counter\",1);\n}\nif (x == \"OFF\")\n{\n    //  Force power OFF\n    msg.payload = \"OFF\";\n    msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    context.set(\"counter\",0);\n}\n\nreturn [msg,msg1];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":870,"y":120,"wires":[["4f29a481b6f0d0e3","0ae8f43ccf9a1016"],["66fb54e88f4acb8d"]]},{"id":"4f29a481b6f0d0e3","type":"delay","z":"94cf2ea396e5b6f6","name":"Delay","pauseType":"delay","timeout":"100","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":1080,"y":120,"wires":[["27d2dd9a875ab1a5"]]},{"id":"27d2dd9a875ab1a5","type":"change","z":"94cf2ea396e5b6f6","name":"#1","rules":[{"t":"set","p":"topic","pt":"msg","to":"DN","tot":"env"},{"t":"set","p":"topic","pt":"msg","to":"topic & '/cmnd/power' & $env(power)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":160,"wires":[[]]},{"id":"7207fbe19cc07923","type":"switch","z":"94cf2ea396e5b6f6","name":"Only for this device","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"DN","vt":"env"},{"t":"eq","v":"MASTER","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":255,"y":160,"wires":[["541720ad73579447"],["6a82c12953657965"]],"l":false},{"id":"0ae8f43ccf9a1016","type":"function","z":"94cf2ea396e5b6f6","name":"Identify","func":"let dev = env.get(\"DN\") + \" \" + env.get(\"power\");\nlet status = msg.payload;\n\nnode.status(dev + \" \" + status);","outputs":1,"noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\nnode.status(env.get(\"DN\"));\n","finalize":"","libs":[],"x":660,"y":270,"wires":[[]]},{"id":"45a85f7621f5c28f","type":"status","z":"94cf2ea396e5b6f6","name":"","scope":["0ae8f43ccf9a1016"],"x":1070,"y":270,"wires":[[]]},{"id":"704ae850657c9724","type":"change","z":"94cf2ea396e5b6f6","name":"Wipe status when unplugged","rules":[{"t":"set","p":"payload","pt":"msg","to":" ","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":425,"y":270,"wires":[["0ae8f43ccf9a1016"]],"l":false},{"id":"0cc9b2fa9b2af8df","type":"switch","z":"94cf2ea396e5b6f6","name":"Reload?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"RELOAD","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":175,"y":160,"wires":[["5b8cd9fe254ea8d1"],["7207fbe19cc07923"]],"l":false},{"id":"66fb54e88f4acb8d","type":"junction","z":"94cf2ea396e5b6f6","x":800,"y":220,"wires":[[]]},{"id":"bfdb3c588016491b","type":"link in","z":"26262ba1.62dcbc","name":"Button","links":["76117c24ef0f5cf3"],"x":1055,"y":4220,"wires":[["7ebd5a2bb58fd95c"]]},{"id":"7ebd5a2bb58fd95c","type":"junction","z":"26262ba1.62dcbc","x":1120,"y":4180,"wires":[["9508b1d704f5549d","5df6f3279accf23f"]]},{"id":"9508b1d704f5549d","type":"subflow:94cf2ea396e5b6f6","z":"26262ba1.62dcbc","name":"","env":[{"name":"DN","value":"A5","type":"str"},{"name":"power","value":"1","type":"num"},{"name":"Device name","value":"A1","type":"str"}],"x":1280,"y":4180,"wires":[["099a494a54542f2d","3b578a30c600e702"],["e87f2ab9ebfdeb7f"]]},{"id":"76117c24ef0f5cf3","type":"link out","z":"26262ba1.62dcbc","name":"Button","mode":"link","links":["bfdb3c588016491b"],"x":1645,"y":4150,"wires":[]},{"id":"e72bae9952eddd60","type":"inject","z":"26262ba1.62dcbc","name":"Button","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"A5/button","payload":"X","payloadType":"str","x":1550,"y":4110,"wires":[["76117c24ef0f5cf3"]]}]
As I said, you need $env('power')
Sorry, we caught each other's toes there.
Yeah, interesting.
The subflow was copied from the working machine and on both the ' are missing.
I'll add them and see what happens.
I am really not having much luck - am I? :wink:
But good catch on that.
Thanks.
THANKS THANKS THANKS.
That seemed to do the trick.
Does it really work on the one machine without the quotes?
Yes, which is why I was so confused.
Quotes taken out, it works.
BUT!
On the other machine, it throws the error.
Can you export that section of the flow please? From the non- working system.
Edit, sorry, I meant the one that works but should not work because of the missing quotes.
This is the node from the machine on which is works.
Note: The node HAS been changed IRL - this export is NOT what is now in the subflow/
        "type": "change",
        "name": "#1",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "DN",
                "tot": "env"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1080,
        "y": 160,
Or did you mean the actual flow?
Or subflow?
Ah, here is the section of the flow.
        "id": "94cf2ea396e5b6f6",
        "type": "subflow",
        "name": "MQTT Button Toggle",
        "info": "# 2023 02 08\nAdded status text to icon to \nshow status of device.\n\n# 2023 01 25\nControl MQTT devices (power points)\nwith this node.\n\n`Button` node MUST have `topic` set to include\nthe device's name.  eg: `A1/button`\nand the payload MUST be `X`\n\nSet the `Device Name` to (eg) `A1` to\ncontrol `A1` device.\n\n`payload` must be `X` to TOGGLE output\n\nsend `ON` to force ON state\n\nsend `OFF` to force OFF state\n\nsend `RELOAD` to force button to\ndisplay current state.\n(added 2024 01 28)\n\n",
        "category": "",
        "in": [
                "x": 100,
                "y": 160,
                        "id": "0cc9b2fa9b2af8df"
        "out": [
                "x": 1280,
                "y": 220,
                        "id": "66fb54e88f4acb8d",
                        "port": 0
                "x": 1250,
                "y": 160,
                        "port": 0
        "env": [
                "name": "DN",
                "type": "str",
                "value": "",
                "ui": {
                    "label": {
                        "en-US": "Device Name"
                    "type": "input",
                    "opts": {
                        "types": [
                            "str"
                "name": "power",
                "type": "num",
                "value": "",
                "ui": {
                    "label": {
                        "en-US": "Output"
                    "type": "input",
                    "opts": {
                        "types": [
                            "num"
        "meta": {},
        "color": "#DDAA99",
        "inputLabels": [
        "outputLabels": [
            "MQTT output"
        "status": {
            "x": 1200,
            "y": 270,
                    "id": "45a85f7621f5c28f",
                    "port": 0
        "id": "541720ad73579447",
        "type": "switch",
        "name": "what message?",
        "property": "topic",
        "propertyType": "msg",
        "rules": [
                "t": "cont",
                "v": "/stat/POWER",
                "vt": "str"
                "t": "cont",
                "v": "/tele/LWT",
                "vt": "str"
                "t": "cont",
                "v": "button",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 3,
        "x": 315,
        "y": 160,
                "61843ca1684f9f9d"
                "4788b5265af1d45a"
                "5b8cd9fe254ea8d1"
        "l": false
        "id": "61843ca1684f9f9d",
        "type": "delay",
        "name": "Delay",
        "pauseType": "delay",
        "timeout": "200",
        "timeoutUnits": "milliseconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 460,
        "y": 80,
                "bdb2c46daf62b36f"
        "id": "6d4704f6fc9b98be",
        "type": "change",
        "name": "RESET",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "RESET",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 470,
        "y": 120,
                "bdb2c46daf62b36f"
        "id": "4788b5265af1d45a",
        "type": "switch",
        "name": "LWT",
        "property": "payload",
        "rules": [
                "t": "eq",
                "v": "Online",
                "vt": "str"
                "t": "eq",
                "v": "Offline",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 460,
        "y": 160,
                "6d4704f6fc9b98be",
                "bc2aabd04561d534"
                "6a82c12953657965"
        "id": "6a82c12953657965",
        "type": "function",
        "name": "BAN",
        "func": "msg = {icon: '<font color = \"red\"><i class=\"fa fa-ban fa-3x\"></i></font>'};\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 460,
        "y": 200,
                "8dc8a0dd2b669ae3",
                "704ae850657c9724"
        "id": "bc2aabd04561d534",
        "type": "change",
        "name": "Enable",
        "rules": [
                "t": "set",
                "p": "enabled",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
                "t": "set",
                "p": "ARLEC-1",
                "pt": "flow",
                "to": "ONLINE",
                "tot": "str"
                "t": "delete",
                "p": "payload",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 660,
        "y": 160,
                "66fb54e88f4acb8d"
        "id": "bdb2c46daf62b36f",
        "type": "function",
        "name": "Set state",
        "func": "let device = msg.topic.split(\"/\");\nnode.warn(\"Device \" + device[0]);\nnode.warn(\"Payload \" + msg.payload);\n\nif (msg.payload == \"RESET\")\n{\n    let state = context.get(device[0]);\n    if (state === 0)\n    {\n        //\n        msg= {\"icon\": '<font color = \"red\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>',\"background\":\"black\"};\n        return msg;\n    }\n    //\n}\nif (msg.payload == \"ON\")\n{\n    msg = { \"icon\": '<font color = \"lime\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"background\": \"black\" };\n    context.set(\"STATE\",1);\n    context.set(device[0],1);\n} else\n{\n    msg = { \"icon\": '<font color = \"red\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>', \"background\": \"black\" };\n    context.set(\"STATE\",0);\n    context.set(device[0], 1);\n}\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 660,
        "y": 120,
                "66fb54e88f4acb8d"
        "id": "8dc8a0dd2b669ae3",
        "type": "change",
        "name": "Disable",
        "rules": [
                "t": "set",
                "p": "enabled",
                "pt": "msg",
                "to": "false",
                "tot": "bool"
                "t": "set",
                "p": "ARLEC-1",
                "pt": "flow",
                "to": "OFFLINE",
                "tot": "str"
                "t": "delete",
                "p": "payload",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 660,
        "y": 200,
                "66fb54e88f4acb8d"
        "id": "5b8cd9fe254ea8d1",
        "type": "function",
        "name": "Button control",
        "func": "let msg1 = {};\n\nlet x = msg.payload;\nlet counter = context.get(\"counter\") || 0;\nif (x == \"X\")\n{\n    counter = (counter + 1) % 2;\n    context.set(\"counter\",counter);\n    if (counter === 0)\n    {\n        //\n        msg.payload = \"OFF\";\n        msg1 = {\"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>',\"background\":\"black\"};\n    } else\n    {\n        //\n        msg.payload = \"ON\";\n        msg1 = {\"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>',\"backgound\":\"black\"};\n    }\n}\nif (x == \"RELOAD\")\n{\n    //  Reload/display status.\n    if (counter == 0)\n    {\n        //  OFF\n        x = \"OFF\";\n        msg.payload = \"OFF\";\n        msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>', \"background\": \"black\" };\n    }\n    else\n    if (counter == 1)\n    {\n        //  ON\n        x = \"ON\";\n        msg.payload = \"ON\";\n        msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    }\n}\n\n\nif (x == \"ON\")\n{\n    //  Force power ON\n    msg.payload = \"ON\";\n    msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    context.set(\"counter\",1);\n}\nif (x == \"OFF\")\n{\n    //  Force power OFF\n    msg.payload = \"OFF\";\n    msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    context.set(\"counter\",0);\n}\n\nreturn [msg,msg1];",
        "outputs": 2,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 870,
        "y": 120,
                "4f29a481b6f0d0e3",
                "0ae8f43ccf9a1016"
                "66fb54e88f4acb8d"
        "id": "4f29a481b6f0d0e3",
        "type": "delay",
        "name": "Delay",
        "timeout": "100",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "outputs": 1,
        "x": 1080,
        "y": 120,
                "27d2dd9a875ab1a5"
        "type": "change",
        "name": "#1",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "DN",
                "tot": "env"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1080,
        "y": 160,
        "id": "7207fbe19cc07923",
        "type": "switch",
        "name": "Only for this device",
        "rules": [
                "t": "cont",
                "v": "DN",
                "vt": "env"
                "t": "eq",
                "v": "MASTER",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 255,
        "y": 160,
                "541720ad73579447"
                "6a82c12953657965"
        "l": false
        "id": "0ae8f43ccf9a1016",
        "type": "function",
        "name": "Identify",
        "func": "let dev = env.get(\"DN\") + \" \" + env.get(\"power\");\nlet status = msg.payload;\n\nnode.status(dev + \" \" + status);",
        "outputs": 1,
        "noerr": 0,
        "initialize": "// Code added here will be run once\n// whenever the node is started.\nnode.status(env.get(\"DN\"));\n",
        "finalize": "",
        "libs": [],
        "x": 660,
        "y": 270,
        "type": "status",
        "scope": [
            "0ae8f43ccf9a1016"
        "x": 1070,
        "y": 270,
        "id": "704ae850657c9724",
        "type": "change",
        "name": "Wipe status when unplugged",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": " ",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 425,
        "y": 270,
                "0ae8f43ccf9a1016"
        "l": false
        "id": "0cc9b2fa9b2af8df",
        "type": "switch",
        "name": "Reload?",
        "rules": [
                "t": "eq",
                "v": "RELOAD",
                "vt": "str"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 175,
        "y": 160,
                "5b8cd9fe254ea8d1"
                "7207fbe19cc07923"
        "l": false
        "type": "junction",
        "x": 800,
        "y": 220,
        "id": "bfdb3c588016491b",
        "type": "link in",
        "z": "26262ba1.62dcbc",
        "name": "Button",
        "links": [
            "76117c24ef0f5cf3"
        "x": 1055,
        "y": 4220,
                "7ebd5a2bb58fd95c"
        "id": "9508b1d704f5549d",
        "type": "subflow:94cf2ea396e5b6f6",
        "env": [
                "name": "DN",
                "value": "A5",
                "type": "str"
                "name": "power",
                "value": "1",
                "type": "num"
                "name": "Device name",
                "value": "A1",
                "type": "str"
        "x": 1280,
        "y": 4180,
                "099a494a54542f2d",
                "3b578a30c600e702"
                "e87f2ab9ebfdeb7f"
        "id": "76117c24ef0f5cf3",
        "type": "link out",
        "name": "Button",
        "mode": "link",
        "links": [
            "bfdb3c588016491b"
        "x": 1645,
        "y": 4150,
        "id": "e72bae9952eddd60",
        "type": "inject",
        "name": "Button",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "A5/button",
        "payload": "X",
        "payloadType": "str",
        "x": 1550,
        "y": 4110,
                "76117c24ef0f5cf3"
I meant export of this, from the machine without the quotes, but which works.
All of it?
Ok.
Um....
Sorry, confusion setting in for me.
As is, on machine B it works either way. With or without the ' around the env name.
Also the one I am posting has the ' around it.
Not wanting to sound difficult, but you can import the code and open/edit the subflow and remove the ' around the env name (power) and try both on your machine.
Do I really need to post both versions (from the same machine?)
[{"id":"94cf2ea396e5b6f6","type":"subflow","name":"MQTT Button Toggle","info":"# 2023 02 08\nAdded status text to icon to \nshow status of device.\n\n# 2023 01 25\nControl MQTT devices (power points)\nwith this node.\n\n`Button` node MUST have `topic` set to include\nthe device's name.  eg: `A1/button`\nand the payload MUST be `X`\n\nSet the `Device Name` to (eg) `A1` to\ncontrol `A1` device.\n\n`payload` must be `X` to TOGGLE output\n\nsend `ON` to force ON state\n\nsend `OFF` to force OFF state\n\nsend `RELOAD` to force button to\ndisplay current state.\n(added 2024 01 28)\n\n","category":"","in":[{"x":100,"y":160,"wires":[{"id":"0cc9b2fa9b2af8df"}]}],"out":[{"x":1280,"y":220,"wires":[{"id":"66fb54e88f4acb8d","port":0}]},{"x":1250,"y":160,"wires":[{"id":"27d2dd9a875ab1a5","port":0}]}],"env":[{"name":"DN","type":"str","value":"","ui":{"label":{"en-US":"Device Name"},"type":"input","opts":{"types":["str"]}}},{"name":"power","type":"num","value":"","ui":{"label":{"en-US":"Output"},"type":"input","opts":{"types":["num"]}}}],"meta":{},"color":"#DDAA99","inputLabels":["MQTT (tele and LWT) and button input"],"outputLabels":["Back to `button` input","MQTT output"],"status":{"x":1200,"y":270,"wires":[{"id":"45a85f7621f5c28f","port":0}]}},{"id":"541720ad73579447","type":"switch","z":"94cf2ea396e5b6f6","name":"what message?","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"/stat/POWER","vt":"str"},{"t":"cont","v":"/tele/LWT","vt":"str"},{"t":"cont","v":"button","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":315,"y":160,"wires":[["61843ca1684f9f9d"],["4788b5265af1d45a"],["5b8cd9fe254ea8d1"]],"l":false},{"id":"61843ca1684f9f9d","type":"delay","z":"94cf2ea396e5b6f6","name":"Delay","pauseType":"delay","timeout":"200","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":460,"y":80,"wires":[["bdb2c46daf62b36f"]]},{"id":"6d4704f6fc9b98be","type":"change","z":"94cf2ea396e5b6f6","name":"RESET","rules":[{"t":"set","p":"payload","pt":"msg","to":"RESET","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":120,"wires":[["bdb2c46daf62b36f"]]},{"id":"4788b5265af1d45a","type":"switch","z":"94cf2ea396e5b6f6","name":"LWT","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Online","vt":"str"},{"t":"eq","v":"Offline","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":460,"y":160,"wires":[["6d4704f6fc9b98be","bc2aabd04561d534"],["6a82c12953657965"]]},{"id":"6a82c12953657965","type":"function","z":"94cf2ea396e5b6f6","name":"BAN","func":"msg = {icon: '<font color = \"red\"><i class=\"fa fa-ban fa-3x\"></i></font>'};\nreturn msg;","outputs":1,"noerr":0,"x":460,"y":200,"wires":[["8dc8a0dd2b669ae3","704ae850657c9724"]]},{"id":"bc2aabd04561d534","type":"change","z":"94cf2ea396e5b6f6","name":"Enable","rules":[{"t":"set","p":"enabled","pt":"msg","to":"true","tot":"bool"},{"t":"set","p":"ARLEC-1","pt":"flow","to":"ONLINE","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":160,"wires":[["66fb54e88f4acb8d"]]},{"id":"bdb2c46daf62b36f","type":"function","z":"94cf2ea396e5b6f6","name":"Set state","func":"let device = msg.topic.split(\"/\");\nnode.warn(\"Device \" + device[0]);\nnode.warn(\"Payload \" + msg.payload);\n\nif (msg.payload == \"RESET\")\n{\n    let state = context.get(device[0]);\n    if (state === 0)\n    {\n        //\n        msg= {\"icon\": '<font color = \"red\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>',\"background\":\"black\"};\n        return msg;\n    }\n    //\n}\nif (msg.payload == \"ON\")\n{\n    msg = { \"icon\": '<font color = \"lime\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"background\": \"black\" };\n    context.set(\"STATE\",1);\n    context.set(device[0],1);\n} else\n{\n    msg = { \"icon\": '<font color = \"red\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>', \"background\": \"black\" };\n    context.set(\"STATE\",0);\n    context.set(device[0], 1);\n}\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":660,"y":120,"wires":[["66fb54e88f4acb8d"]]},{"id":"8dc8a0dd2b669ae3","type":"change","z":"94cf2ea396e5b6f6","name":"Disable","rules":[{"t":"set","p":"enabled","pt":"msg","to":"false","tot":"bool"},{"t":"set","p":"ARLEC-1","pt":"flow","to":"OFFLINE","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":200,"wires":[["66fb54e88f4acb8d"]]},{"id":"5b8cd9fe254ea8d1","type":"function","z":"94cf2ea396e5b6f6","name":"Button control","func":"let msg1 = {};\n\nlet x = msg.payload;\nlet counter = context.get(\"counter\") || 0;\nif (x == \"X\")\n{\n    counter = (counter + 1) % 2;\n    context.set(\"counter\",counter);\n    if (counter === 0)\n    {\n        //\n        msg.payload = \"OFF\";\n        msg1 = {\"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>',\"background\":\"black\"};\n    } else\n    {\n        //\n        msg.payload = \"ON\";\n        msg1 = {\"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>',\"backgound\":\"black\"};\n    }\n}\nif (x == \"RELOAD\")\n{\n    //  Reload/display status.\n    if (counter == 0)\n    {\n        //  OFF\n        x = \"OFF\";\n        msg.payload = \"OFF\";\n        msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>', \"background\": \"black\" };\n    }\n    else\n    if (counter == 1)\n    {\n        //  ON\n        x = \"ON\";\n        msg.payload = \"ON\";\n        msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    }\n}\n\n\nif (x == \"ON\")\n{\n    //  Force power ON\n    msg.payload = \"ON\";\n    msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    context.set(\"counter\",1);\n}\nif (x == \"OFF\")\n{\n    //  Force power OFF\n    msg.payload = \"OFF\";\n    msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    context.set(\"counter\",0);\n}\n\nreturn [msg,msg1];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":870,"y":120,"wires":[["4f29a481b6f0d0e3","0ae8f43ccf9a1016"],["66fb54e88f4acb8d"]]},{"id":"4f29a481b6f0d0e3","type":"delay","z":"94cf2ea396e5b6f6","name":"Delay","pauseType":"delay","timeout":"100","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":1080,"y":120,"wires":[["27d2dd9a875ab1a5"]]},{"id":"27d2dd9a875ab1a5","type":"change","z":"94cf2ea396e5b6f6","name":"#1","rules":[{"t":"set","p":"topic","pt":"msg","to":"DN","tot":"env"},{"t":"set","p":"topic","pt":"msg","to":"topic & '/cmnd/power' & $env('power')","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":160,"wires":[[]]},{"id":"7207fbe19cc07923","type":"switch","z":"94cf2ea396e5b6f6","name":"Only for this device","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"DN","vt":"env"},{"t":"eq","v":"MASTER","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":255,"y":160,"wires":[["541720ad73579447"],["6a82c12953657965"]],"l":false},{"id":"0ae8f43ccf9a1016","type":"function","z":"94cf2ea396e5b6f6","name":"Identify","func":"let dev = env.get(\"DN\") + \" \" + env.get(\"power\");\nlet status = msg.payload;\n\nnode.status(dev + \" \" + status);","outputs":1,"noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\nnode.status(env.get(\"DN\"));\n","finalize":"","libs":[],"x":660,"y":270,"wires":[[]]},{"id":"45a85f7621f5c28f","type":"status","z":"94cf2ea396e5b6f6","name":"","scope":["0ae8f43ccf9a1016"],"x":1070,"y":270,"wires":[[]]},{"id":"704ae850657c9724","type":"change","z":"94cf2ea396e5b6f6","name":"Wipe status when unplugged","rules":[{"t":"set","p":"payload","pt":"msg","to":" ","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":425,"y":270,"wires":[["0ae8f43ccf9a1016"]],"l":false},{"id":"0cc9b2fa9b2af8df","type":"switch","z":"94cf2ea396e5b6f6","name":"Reload?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"RELOAD","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":175,"y":160,"wires":[["5b8cd9fe254ea8d1"],["7207fbe19cc07923"]],"l":false},{"id":"66fb54e88f4acb8d","type":"junction","z":"94cf2ea396e5b6f6","x":800,"y":220,"wires":[[]]},{"id":"9508b1d704f5549d","type":"subflow:94cf2ea396e5b6f6","z":"26262ba1.62dcbc","name":"","env":[{"name":"DN","value":"A5","type":"str"},{"name":"power","value":"1","type":"num"},{"name":"Device name","value":"A1","type":"str"}],"x":1280,"y":4180,"wires":[["099a494a54542f2d","3b578a30c600e702"],["e87f2ab9ebfdeb7f"]]},{"id":"7ebd5a2bb58fd95c","type":"junction","z":"26262ba1.62dcbc","x":1120,"y":4180,"wires":[["9508b1d704f5549d","5df6f3279accf23f"]]},{"id":"099a494a54542f2d","type":"ui_button","z":"26262ba1.62dcbc","name":"A5","group":"5dde4bf66eb38aa1","order":0,"width":"1","height":"1","passthru":false,"label":"{{msg.icon}}","tooltip":"","color":"","bgcolor":"{{msg.background}}","className":"","icon":"","payload":"X","payloadType":"str","topic":"A5/button","topicType":"str","x":1550,"y":4150,"wires":[["76117c24ef0f5cf3"]]},{"id":"3b578a30c600e702","type":"debug","z":"26262ba1.62dcbc","name":"To button","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1560,"y":4070,"wires":[]},{"id":"e87f2ab9ebfdeb7f","type":"mqtt out","z":"26262ba1.62dcbc","name":"","topic":"","qos":"0","retain":"true","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"378c0403.8cda04","x":1550,"y":4200,"wires":[]},{"id":"711c549e46cbf75d","type":"mqtt in","z":"26262ba1.62dcbc","name":"","topic":"A5/tele/LWT","qos":"2","datatype":"auto","broker":"378c0403.8cda04","nl":false,"rap":false,"inputs":0,"x":1000,"y":4180,"wires":[["7ebd5a2bb58fd95c"]],"info":"Needs editing if used for another device"},{"id":"39df276d4a56640f","type":"mqtt in","z":"26262ba1.62dcbc","name":"","topic":"A5/stat/POWER","qos":"2","datatype":"auto","broker":"378c0403.8cda04","nl":false,"rap":false,"inputs":0,"x":990,"y":4130,"wires":[["7ebd5a2bb58fd95c"]]},{"id":"bfdb3c588016491b","type":"link in","z":"26262ba1.62dcbc","name":"Button","links":["76117c24ef0f5cf3"],"x":1055,"y":4220,"wires":[["7ebd5a2bb58fd95c"]]},{"id":"8e225fcb5089da4c","type":"inject","z":"26262ba1.62dcbc","name":"Offline","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"A5/tele/LWT","payload":"Offline","payloadType":"str","x":1020,"y":4260,"wires":[["7ebd5a2bb58fd95c"]]},{"id":"5b0a3e68c203869e","type":"inject","z":"26262ba1.62dcbc","name":"Online","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"A5/tele/LWT","payload":"Online","payloadType":"str","x":1020,"y":4300,"wires":[["7ebd5a2bb58fd95c"]]},{"id":"5df6f3279accf23f","type":"debug","z":"26262ba1.62dcbc","name":"Going IN","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1220,"y":4080,"wires":[]},{"id":"76117c24ef0f5cf3","type":"link out","z":"26262ba1.62dcbc","name":"Button","mode":"link","links":["bfdb3c588016491b"],"x":1645,"y":4150,"wires":[]},{"id":"e72bae9952eddd60","type":"inject","z":"26262ba1.62dcbc","name":"Button","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"A5/button","payload":"X","payloadType":"str","x":1550,"y":4110,"wires":[["76117c24ef0f5cf3"]]},{"id":"5dde4bf66eb38aa1","type":"ui_group","name":"A(1-4) Sockets","tab":"aa487daa.33c1c","order":9,"disp":true,"width":"4","collapse":false,"className":""},{"id":"378c0403.8cda04","type":"mqtt-broker","name":"TIMEPI MQTT","broker":"192.168.17.39","port":"1883","clientid":"","autoConnect":true,"usetls":false,"compatmode":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"true","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"aa487daa.33c1c","type":"ui_tab","name":"Real_World_Control","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
Yes, it would be nice to understand what is going on.
Why both machines are running the same NR version, same Node version and have the same change node version.
(One is a RasPi one is a NUC)
As it is a SUBFLOW, I can't really have BOTH versions loaded at the same time. (easily)
I would like you to take the quotes out, restart node-red, check it still works, and export that please. I want to know for certain that I am looking at a valid flow.
Yeah, ok. That's do-able.
BRB.
WITHOUT the ' around the env name.
NR restarted and message working.
[{"id":"94cf2ea396e5b6f6","type":"subflow","name":"MQTT Button Toggle","info":"# 2023 02 08\nAdded status text to icon to \nshow status of device.\n\n# 2023 01 25\nControl MQTT devices (power points)\nwith this node.\n\n`Button` node MUST have `topic` set to include\nthe device's name.  eg: `A1/button`\nand the payload MUST be `X`\n\nSet the `Device Name` to (eg) `A1` to\ncontrol `A1` device.\n\n`payload` must be `X` to TOGGLE output\n\nsend `ON` to force ON state\n\nsend `OFF` to force OFF state\n\nsend `RELOAD` to force button to\ndisplay current state.\n(added 2024 01 28)\n\n","category":"","in":[{"x":100,"y":160,"wires":[{"id":"0cc9b2fa9b2af8df"}]}],"out":[{"x":1280,"y":220,"wires":[{"id":"66fb54e88f4acb8d","port":0}]},{"x":1250,"y":160,"wires":[{"id":"27d2dd9a875ab1a5","port":0}]}],"env":[{"name":"DN","type":"str","value":"","ui":{"label":{"en-US":"Device Name"},"type":"input","opts":{"types":["str"]}}},{"name":"power","type":"num","value":"","ui":{"label":{"en-US":"Output"},"type":"input","opts":{"types":["num"]}}}],"meta":{},"color":"#DDAA99","inputLabels":["MQTT (tele and LWT) and button input"],"outputLabels":["Back to `button` input","MQTT output"],"status":{"x":1200,"y":270,"wires":[{"id":"45a85f7621f5c28f","port":0}]}},{"id":"541720ad73579447","type":"switch","z":"94cf2ea396e5b6f6","name":"what message?","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"/stat/POWER","vt":"str"},{"t":"cont","v":"/tele/LWT","vt":"str"},{"t":"cont","v":"button","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":315,"y":160,"wires":[["61843ca1684f9f9d"],["4788b5265af1d45a"],["5b8cd9fe254ea8d1"]],"l":false},{"id":"61843ca1684f9f9d","type":"delay","z":"94cf2ea396e5b6f6","name":"Delay","pauseType":"delay","timeout":"200","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":460,"y":80,"wires":[["bdb2c46daf62b36f"]]},{"id":"6d4704f6fc9b98be","type":"change","z":"94cf2ea396e5b6f6","name":"RESET","rules":[{"t":"set","p":"payload","pt":"msg","to":"RESET","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":120,"wires":[["bdb2c46daf62b36f"]]},{"id":"4788b5265af1d45a","type":"switch","z":"94cf2ea396e5b6f6","name":"LWT","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Online","vt":"str"},{"t":"eq","v":"Offline","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":460,"y":160,"wires":[["6d4704f6fc9b98be","bc2aabd04561d534"],["6a82c12953657965"]]},{"id":"6a82c12953657965","type":"function","z":"94cf2ea396e5b6f6","name":"BAN","func":"msg = {icon: '<font color = \"red\"><i class=\"fa fa-ban fa-3x\"></i></font>'};\nreturn msg;","outputs":1,"noerr":0,"x":460,"y":200,"wires":[["8dc8a0dd2b669ae3","704ae850657c9724"]]},{"id":"bc2aabd04561d534","type":"change","z":"94cf2ea396e5b6f6","name":"Enable","rules":[{"t":"set","p":"enabled","pt":"msg","to":"true","tot":"bool"},{"t":"set","p":"ARLEC-1","pt":"flow","to":"ONLINE","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":160,"wires":[["66fb54e88f4acb8d"]]},{"id":"bdb2c46daf62b36f","type":"function","z":"94cf2ea396e5b6f6","name":"Set state","func":"let device = msg.topic.split(\"/\");\nnode.warn(\"Device \" + device[0]);\nnode.warn(\"Payload \" + msg.payload);\n\nif (msg.payload == \"RESET\")\n{\n    let state = context.get(device[0]);\n    if (state === 0)\n    {\n        //\n        msg= {\"icon\": '<font color = \"red\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>',\"background\":\"black\"};\n        return msg;\n    }\n    //\n}\nif (msg.payload == \"ON\")\n{\n    msg = { \"icon\": '<font color = \"lime\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"background\": \"black\" };\n    context.set(\"STATE\",1);\n    context.set(device[0],1);\n} else\n{\n    msg = { \"icon\": '<font color = \"red\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>', \"background\": \"black\" };\n    context.set(\"STATE\",0);\n    context.set(device[0], 1);\n}\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":660,"y":120,"wires":[["66fb54e88f4acb8d"]]},{"id":"8dc8a0dd2b669ae3","type":"change","z":"94cf2ea396e5b6f6","name":"Disable","rules":[{"t":"set","p":"enabled","pt":"msg","to":"false","tot":"bool"},{"t":"set","p":"ARLEC-1","pt":"flow","to":"OFFLINE","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":200,"wires":[["66fb54e88f4acb8d"]]},{"id":"5b8cd9fe254ea8d1","type":"function","z":"94cf2ea396e5b6f6","name":"Button control","func":"let msg1 = {};\n\nlet x = msg.payload;\nlet counter = context.get(\"counter\") || 0;\nif (x == \"X\")\n{\n    counter = (counter + 1) % 2;\n    context.set(\"counter\",counter);\n    if (counter === 0)\n    {\n        //\n        msg.payload = \"OFF\";\n        msg1 = {\"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>',\"background\":\"black\"};\n    } else\n    {\n        //\n        msg.payload = \"ON\";\n        msg1 = {\"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>',\"backgound\":\"black\"};\n    }\n}\nif (x == \"RELOAD\")\n{\n    //  Reload/display status.\n    if (counter == 0)\n    {\n        //  OFF\n        x = \"OFF\";\n        msg.payload = \"OFF\";\n        msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-270 fa-3x\"></i></font>', \"background\": \"black\" };\n    }\n    else\n    if (counter == 1)\n    {\n        //  ON\n        x = \"ON\";\n        msg.payload = \"ON\";\n        msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    }\n}\n\n\nif (x == \"ON\")\n{\n    //  Force power ON\n    msg.payload = \"ON\";\n    msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    context.set(\"counter\",1);\n}\nif (x == \"OFF\")\n{\n    //  Force power OFF\n    msg.payload = \"OFF\";\n    msg1 = { \"icon\": '<font color = \"orangered\"><i class=\"fa fa-toggle-on fa-rotate-90 fa-3x\"></i></font>', \"backgound\": \"black\" };\n    context.set(\"counter\",0);\n}\n\nreturn [msg,msg1];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":870,"y":120,"wires":[["4f29a481b6f0d0e3","0ae8f43ccf9a1016"],["66fb54e88f4acb8d"]]},{"id":"4f29a481b6f0d0e3","type":"delay","z":"94cf2ea396e5b6f6","name":"Delay","pauseType":"delay","timeout":"100","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":1080,"y":120,"wires":[["27d2dd9a875ab1a5"]]},{"id":"27d2dd9a875ab1a5","type":"change","z":"94cf2ea396e5b6f6","name":"#1","rules":[{"t":"set","p":"topic","pt":"msg","to":"DN","tot":"env"},{"t":"set","p":"topic","pt":"msg","to":"topic & '/cmnd/power' & $env(power)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":160,"wires":[[]]},{"id":"7207fbe19cc07923","type":"switch","z":"94cf2ea396e5b6f6","name":"Only for this device","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"DN","vt":"env"},{"t":"eq","v":"MASTER","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":255,"y":160,"wires":[["541720ad73579447"],["6a82c12953657965"]],"l":false},{"id":"0ae8f43ccf9a1016","type":"function","z":"94cf2ea396e5b6f6","name":"Identify","func":"let dev = env.get(\"DN\") + \" \" + env.get(\"power\");\nlet status = msg.payload;\n\nnode.status(dev + \" \" + status);","outputs":1,"noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\nnode.status(env.get(\"DN\"));\n","finalize":"","libs":[],"x":660,"y":270,"wires":[[]]},{"id":"45a85f7621f5c28f","type":"status","z":"94cf2ea396e5b6f6","name":"","scope":["0ae8f43ccf9a1016"],"x":1070,"y":270,"wires":[[]]},{"id":"704ae850657c9724","type":"change","z":"94cf2ea396e5b6f6","name":"Wipe status when unplugged","rules":[{"t":"set","p":"payload","pt":"msg","to":" ","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":425,"y":270,"wires":[["0ae8f43ccf9a1016"]],"l":false},{"id":"0cc9b2fa9b2af8df","type":"switch","z":"94cf2ea396e5b6f6","name":"Reload?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"RELOAD","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":175,"y":160,"wires":[["5b8cd9fe254ea8d1"],["7207fbe19cc07923"]],"l":false},{"id":"66fb54e88f4acb8d","type":"junction","z":"94cf2ea396e5b6f6","x":800,"y":220,"wires":[[]]},{"id":"9508b1d704f5549d","type":"subflow:94cf2ea396e5b6f6","z":"26262ba1.62dcbc","name":"","env":[{"name":"DN","value":"A5","type":"str"},{"name":"power","value":"1","type":"num"},{"name":"Device name","value":"A1","type":"str"}],"x":1280,"y":4180,"wires":[["099a494a54542f2d","3b578a30c600e702"],["e87f2ab9ebfdeb7f"]]},{"id":"7ebd5a2bb58fd95c","type":"junction","z":"26262ba1.62dcbc","x":1120,"y":4180,"wires":[["9508b1d704f5549d","5df6f3279accf23f"]]},{"id":"099a494a54542f2d","type":"ui_button","z":"26262ba1.62dcbc","name":"A5","group":"5dde4bf66eb38aa1","order":0,"width":"1","height":"1","passthru":false,"label":"{{msg.icon}}","tooltip":"","color":"","bgcolor":"{{msg.background}}","className":"","icon":"","payload":"X","payloadType":"str","topic":"A5/button","topicType":"str","x":1550,"y":4150,"wires":[["76117c24ef0f5cf3"]]},{"id":"3b578a30c600e702","type":"debug","z":"26262ba1.62dcbc","name":"To button","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1560,"y":4070,"wires":[]},{"id":"e87f2ab9ebfdeb7f","type":"mqtt out","z":"26262ba1.62dcbc","name":"","topic":"","qos":"0","retain":"true","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"378c0403.8cda04","x":1550,"y":4200,"wires":[]},{"id":"711c549e46cbf75d","type":"mqtt in","z":"26262ba1.62dcbc","name":"","topic":"A5/tele/LWT","qos":"2","datatype":"auto","broker":"378c0403.8cda04","nl":false,"rap":false,"inputs":0,"x":1000,"y":4180,"wires":[["7ebd5a2bb58fd95c"]],"info":"Needs editing if used for another device"},{"id":"39df276d4a56640f","type":"mqtt in","z":"26262ba1.62dcbc","name":"","topic":"A5/stat/POWER","qos":"2","datatype":"auto","broker":"378c0403.8cda04","nl":false,"rap":false,"inputs":0,"x":990,"y":4130,"wires":[["7ebd5a2bb58fd95c"]]},{"id":"bfdb3c588016491b","type":"link in","z":"26262ba1.62dcbc","name":"Button","links":["76117c24ef0f5cf3"],"x":1055,"y":4220,"wires":[["7ebd5a2bb58fd95c"]]},{"id":"8e225fcb5089da4c","type":"inject","z":"26262ba1.62dcbc","name":"Offline","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"A5/tele/LWT","payload":"Offline","payloadType":"str","x":1020,"y":4260,"wires":[["7ebd5a2bb58fd95c"]]},{"id":"5b0a3e68c203869e","type":"inject","z":"26262ba1.62dcbc","name":"Online","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"A5/tele/LWT","payload":"Online","payloadType":"str","x":1020,"y":4300,"wires":[["7ebd5a2bb58fd95c"]]},{"id":"5df6f3279accf23f","type":"debug","z":"26262ba1.62dcbc","name":"Going IN","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1220,"y":4080,"wires":[]},{"id":"76117c24ef0f5cf3","type":"link out","z":"26262ba1.62dcbc","name":"Button","mode":"link","links":["bfdb3c588016491b"],"x":1645,"y":4150,"wires":[]},{"id":"e72bae9952eddd60","type":"inject","z":"26262ba1.62dcbc","name":"Button","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"A5/button","payload":"X","payloadType":"str","x":1550,"y":4110,"wires":[["76117c24ef0f5cf3"]]},{"id":"5dde4bf66eb38aa1","type":"ui_group","name":"A(1-4) Sockets","tab":"aa487daa.33c1c","order":9,"disp":true,"width":"4","collapse":false,"className":""},{"id":"378c0403.8cda04","type":"mqtt-broker","name":"TIMEPI MQTT","broker":"192.168.17.39","port":"1883","clientid":"","autoConnect":true,"usetls":false,"compatmode":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"true","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"aa487daa.33c1c","type":"ui_tab","name":"Real_World_Control","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
And to be clear: This machine works with or without the '.
(I'll go to the other machine and show you what happens without the ' in the subflow.)
That will be another reply giving you time to look at what is so far.
No need for that.
What happens if you click the Inject node called Button?
That's what I am doing at this stage.
Keep things in/on the EDIT screen.
Sorry the pictures/screengrab didn't quite clearly show that.
My bad.
Sorry.
