Scargill's thermostat
Hi all!
I'm trying to use Scargill's thermostat.
I've imported his flow on a VPS and it seems to be working, I've imported it on a Raspberry and everywhere I click on the UI nothing happens and in the log I see:
[function:xxxxx] TypeError: Cannot read properties of undefined (reading 'xxx')
I've deleted the flow (the file), removed the context files and started again with the same result.
What the heck is wrong?
Peter does not visit the forums much anymore - and has previously stated he will only supply support on his blog - you would be best visiting him over there and raising an issue
Craig
If you tag Peter like this @scargill , then he will get a notification about this topic.
