jbudd
12 November 2023 14:02
1
I have a ui_tab called test stuff.
There is one group with two ui-charts on the tab
If I search flows for "test stuff" it returns the tab but neither the group nor the widgets on it, although their config does include "test stuff"
Also if I click on the search result it takes me to the sidebar where clicking on the tab name opens the edit dialog. I can't see a way to go to the flow which defines this tab and it's widgets?
jbudd
21 November 2023 10:40
2
No comments?
Perhaps I'm missing an obvious work-around?
It would be nice if the ui_tab in the find results would take you to the sidebar dashboard so you could see what it contained.
@jbudd please raise an issue so this doesn't get overlooked.
The [test stuff] is part of the node's label. At a glance this suggests the search isn't including that in what it searches.
jbudd
21 November 2023 13:36
5
I'll try to nail down the issue.
It may be related to spaces in the tab/group names.
Nope, something goes wrong when existing ui-tab/ui-group names are changed.
