Now flow and new ui
Sirry for the stupid question
I have two flow, one is for one test and the other is for trotally different test:
In the fow1 i have already done the ui.
but if i deploy the fow 2 and i go in the ui i see the flow 1 + flow2
where is my stupid error??
Without seeing your flows it would be to give an exact solution. You haven't said if you add dashboard items to flow 2, but assuming you did you probably put them in the same tab and group.
If you go to the editor's right sidebar, you can select the 'Tabs & Links'
Screenshot 2023-07-05 at 11.00.36 AM
