Searching for help to read status of Edimax Smartplug
I would like to read the status of my Edimax SP-2101W Smartplugs. They have firmware 3.00 installed. Unfortunately the node "node-red-contrib-smartplug" seems not to be working.
Can anybody help me?
Many thanks!
Harald
That works with my smartplug but mine is somewhat old and I've never updated the firmware (or at least not for a long time).
Are there any errors?
The node first shows "initializing" and then "disconnected".
I guess that if you have the right connection details, the firmware must have changed the API.
I'm afraid that you will need to raise an issue on GitHub and hope that the author is still active.
I have now downgraded one of my smartplugs to Version 1.00b.
But I still get "disconnected". Maybe I'm using the wrong credentials.
What are you using as username and password?
I tried "admin" and "1234" as well as the email address and password I used for registering the smartplug in the Edismart App.
Many thanks for your support.
Harald
The reason for the Edimax SP-2101W V2 with Firmware 3.00c not working with node-red-contrib-smartplug is a wrong password. While the username ist still "admin", the password is generated during the setup of the Smartplug using the EdiSmart App.
To find out this password it is necessary to perform the following steps:
  1. Find out the IP your Smartplug is actually using (you will need this in step 9).
  2. Delete the Smartplug from the EdiSmart App
  3. Perform a factory reset on the Smartplug
  4. As soon as the Smartplug is in "Installation Mode", connect your Smartphone with the "EdiPlug.Setup xx" WLAN as well as your PC.
  5. In the browser on your PC enter "http://192.168.20.3:10000/tnb2". The response should be "OK".
  6. On your Smartphone open the EdiSmart App
  7. On your PC connect again to your "normal" WLAN
  8. On your Smartphone select the WLAN and password for your Smartplug
  9. As soon as you are requested to enter a new name for your Smartplug, start Telnet with the IP from step 1 and Port 1355 on your PC
  10. On your Smartphone type in the new name for your Smartplug and press OK
  11. Now immediately, and while your Smartphone is still configuring your Smartplug, type in "nvc all" in the Telnet session on your PC. At the end of the list a password different than "1234" should be shown. If not, again type in "nvc all" until the newly generated password is displayed.
Harald
Good catch!
Perhaps if you opened an issue on the nodes github page the author could include it in the Readme / other docs for the node.
