Colin,
Sorry me... while I asked I was researching about the application, and I thought that I could improve my question, sorry.
I think the best think to do is close this topic and begin a new one, right?
I really loved the application that @BartButenaers showed me.
thak you Colin and thank you for all your help!
Yes, it is possible, but look:
I want to do that my suplier see the data that I'm seeing - I don't want to have mismatch of information (it could happen using the same datas in two differents systems).
Thank you Steve. I really appreciate your attention and information!
Just my 2 cents here: I have moved files very easily between Linux machines (Raspberry Pis and Ubuntu etc) using and exec node to scp with ssh. I use this to pull video and picture files from security cams made from Pi computers.
The command entered into the exec node looks something like this"
scp pi@192.168.1.122:/var/lib/motion/* /home/will/.node-red/static/motion/storage/
More details if you are not familiar with ssh shell commands:
Basically scp is the same as the cp (copy) command. Think of it as ssh-copy.
The above command is run on my Ubuntu 'server' machine and retrieves files from a pi camera.
You need ssh working on both machines and the server needs to have a key copied to the Pi so you can run without password. To do this, run the following terminal command on the machine that will be running the scp command:
# you only need keygen if you have never done it before on this machine
ssh-keygen
# copy id to other machine
ssh-copy-id pi@192.168.1.122
Now you can run ssh without a password.
Also you can run more complex operations by using the exec node to run a shell script like this:
#!/bin/bash
today=`date +%Y-%m-%d.%H:%M:%S`
# $1 first imput parameter will be day of month 1-31
# $2 second imput parameter will be the last IP address number 192.168.1.XXX 0-255
# the -p parameter makes directories and subdirectories if they do not exist
mkdir -p /home/will/.node-red/static/motion/$1/$2
#ssh pi@192.168.1.204 "sudo dd if=/etc/motion/motion.conf bs=1M" | dd of=backup-motion.conf
# remove old files
rm /home/will/.node-red/static/motion/$1/$2/*
echo getting files from pi
scp pi@192.168.1.$2:/var/lib/motion/* /home/will/.node-red/static/motion/$1/$2/
# count files moved to new location
# output will be in msg.payload from the exec node
ls /home/will/.node-red/static/motion/$1/$2 -1 | wc -l
