I’m trying to send out the payload from a sensor reading from one Raspberry pi to another Raspberry Pi . This way I can have multiple readings in one Dashboard. I tried using the TCP output and Input and they connect but the payload msg comes out in Hex instead of the readings from the sensor. Is this the right route I’m taking by using TCP? Or is there any other way to transfer from one system to another. Do I have to format the output prior to using the TCP node? Any guidance would be greatly appreciated.
Best Regards,
Pedro Fuentes
