Sending Commands over TCP with a node only for USB
Great thank you! Now I can analyze it better!!
Just check that strange message received earlier above
['I2C', '192.168.12.194', '50', '6', 'ON']
b'\xaa\x01U\x00\xaa\x01\x10\xbb'
85
Here is something not ok, the response is too long and seems to be a mix of two responses. I think I will have to figure out some clever filtering. The last log you provided looks perfect I think. It translates to decimal 170 1 0 171 (all relays are off)
OK, a new attempt
The response above, b'\xaa\x01U\x00\xaa\x01\x10\xbb', seems partly correct, the last 4 bytes are actually the response we are expecting. So selecting those last bytes would give a correct result. I have introduced a small check that try to recover those, hopefully rare, occasions (and printing the incoming response to give a log of those, who knows how many and if they will look differently?)
Added also printout of the actual command that is sent to turn a relay on/off. This seemed not working? So we need to verify that I got it correct, at least from formatting and checksum calculation perspective
Hopefully it works, fingers crossed
# coding: utf-8
import sys
import os
import socket
import time
import subprocess
import signal
import paho.mqtt.client as mqtt
from setproctitle import setproctitle
def on_connect(client, obj, flags, rc):
    client.subscribe("cmnds", 0)
def on_subscribe(client, userdata, mid, granted_qos):
    print ('Subscribed:', userdata, mid, granted_qos)
    print ('We are here, waiting for button commands...')
def on_message(mosq, obj, msg):
    global abort
    TCP_PORT = 2101
    BUFFER_SIZE = 1024
    cmds = {
        "R1_ON" : bytes ((170,3,254,108,1,24)),
        "R1_OFF" : bytes ((170,3,254,100,1,16)),
        "R2_ON" : bytes ((170,3,254,109,1,25)),
        "R2_OFF" : bytes ((170,3,254,101,1,17)),
        "R3_ON" : bytes ((170,3,254,110,1,26)),
        "R3_OFF" : bytes((170,3,254,102,1,18)),
        "R4_ON" : bytes ((170,3,254,111,1,27)),
        "R4_OFF" : bytes ((170,3,254,103,1,19)),
        "R5_ON" : bytes ((170,3,254,112,1,28)),
        "R5_OFF" : bytes ((170,3,254,104,1,20)),
        "R6_ON" : bytes ((170,3,254,113,1,29)),
        "R6_OFF" : bytes((170,3,254,105,1,21)),
        "R7_ON" : bytes ((170,3,254,114,1,30)),
        "R7_OFF" : bytes ((170,3,254,106,1,22)),
        "R8_ON" : bytes ((170,3,254,115,1,31)),
        "R8_OFF" : bytes ((170,3,254,107,1,23))
    event = msg.payload.decode("utf-8").split(',')
    print (event)
    if event[0] == 'abort':
        abort = True
    if "_O" in event[0]:
        print ("filtered:", event[0])
        s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
        p = s.connect((event[1], TCP_PORT))
        s.sendall((cmds[event[0]]))
        s.close()
        del(s)
    if "I2C" in event[0]:
        Ip = event[1]
        iPort = int(event[2])
        iRelay = int(event[3])
        relayState = event[4]
        dValues = {"1":1, "2":2, "3":4, "4":8, "5":16, "6":32, "7":64, "8":128}
        rValues = [1,2,4,8,16,32,64,128]
        #Check relay states
        chkSum = (170+5+188+iPort+1+65+1) & 255
        cmd = bytes ((170,5,188,iPort,1,65,1,chkSum))
        p = s.connect((Ip, TCP_PORT))
        s.sendall((cmd))
        res = s.recv((BUFFER_SIZE))
#        res = b'\xaa\x01U\x00\xaa\x01\x10\xbb'
        #Check that the response length is not > 4
        if len(res) > 4:
            print (res)
            res = res[-4:]
        iSum = int(res[2])
        print ("Sum of current relay statuses: ", iSum)
        rStates = []
        for i in rValues[::-1]:
            if iSum-i >= 0:
                rStates.append(i)
                iSum = iSum-i
            else:
                rStates.append(0)
        #Reverse resulting list of current relay statuses
        rStates = rStates[::-1]
        if relayState == "ON":
            rStates[iRelay-1]=rValues[iRelay-1]
        if relayState == "OFF":
            rStates[iRelay-1]=0
        #Send the new relay command
        time.sleep(0.01)
        iSum =  sum(rStates)
        print ("Sum of new relay statuses: ", iSum)
        chkSum = (170+7+188+iPort+3+64+9+iSum+0) & 255
        cmd = bytes ((170,7,188,iPort,3,64,9,iSum,0,chkSum))
        print (170,7,188,iPort,3,64,9,iSum,0,chkSum)
        s.sendall((cmd))
        time.sleep(0.1)
        s.close()
        del(s)
p = subprocess.Popen(['ps', '-A'], stdout=subprocess.PIPE)
out, err = p.communicate()
for line in out.splitlines():
    #print (line)
    if b'relay_control' in line:
        pid = int(line.split(None, 1)[0])
        print ('Killing ', pid)
        os.kill(pid, signal.SIGKILL)
time.sleep(2)
nn = 'relay_control'
setproctitle (nn)
abort = False
client = mqtt.Mosquitto()
client.on_connect = on_connect
client.on_message = on_message
client.on_subscribe = on_subscribe
client.connect("127.0.0.1", 1883, 60)
client.loop_start()
#if not os.geteuid() == 0:
#    sys.exit("script only works as root")
while not abort:
    time.sleep(1)
client.loop_stop()
client.disconnect()
del client
exit(0)
This is what happens when switching from OFF to ON. But nothing happens.
I will start reading the new information on how to best control the new boards.
['I2C', '192.168.12.194', '50', '1', 'ON']
Sum of current relay statuses: 0
Sum of new relay statuses: 1
170 7 188 50 3 64 9 1 0 236
['I2C', '192.168.12.194', '50', '2', 'ON']
Sum of new relay statuses: 2
170 7 188 50 3 64 9 2 0 237
['I2C', '192.168.12.194', '50', '3', 'ON']
Sum of new relay statuses: 4
170 7 188 50 3 64 9 4 0 239
['I2C', '192.168.12.194', '50', '4', 'ON']
Sum of new relay statuses: 8
170 7 188 50 3 64 9 8 0 243
['I2C', '192.168.12.194', '50', '5', 'ON']
Sum of new relay statuses: 16
170 7 188 50 3 64 9 16 0 251
Sum of new relay statuses: 32
170 7 188 50 3 64 9 32 0 11
['I2C', '192.168.12.194', '50', '7', 'ON']
Sum of new relay statuses: 64
170 7 188 50 3 64 9 64 0 43
['I2C', '192.168.12.194', '50', '8', 'ON']
Sum of new relay statuses: 128
170 7 188 50 3 64 9 128 0 107
New boards? Are they not compatible with the protocol information I have had so far???
If I look at the log it looks as I calculate the checksum & format the command correctly
Like in these cases:
170 7 188 50 3 64 9 64 0 43 (The checksum is correctly calculated to 43)
170 7 188 50 3 64 9 128 0 107 (The checksum is correctly calculated to 107)
As you say, since no relay gets activated, we get "Sum of current relay statuses: 0" all the time
The other / new boards will go on the I2C port hub, and according to the company the commands should be even easier. It will use the same protocol,but maybe easier.
The protocol for the newer controller (8-Port) has changed (from the older 5-Port), the port selection you are referring to is in the older format. The newer format is explicit, 1 = Port 1, 3 = Port 3, etc. Newer controller also supports write read commands while directing commands to each port. Please take a close look at the docs for the new 8 port controller and do not try to use the 188 command any longer. The new format is far easier to use. Hope this helps.
Ryan
But for the moment i do not know the information for myself as i can not figure this out so far.
This is the I2C port board where the relay boards will be on.
Thank you already very much for your help so far!
This is making me worried since it is exactly what I'm using
i have maken a project that for TCP control ethernet relay board , now running on Raspberry pi. if you want i can send you flows, but this is for TCP/IP control relay use, not for USB.
Dear,
Thank you very much, but with a lot of great and successful help of krambriw i'm able to control everything i want. I will let you know my solution when its complete.
