I have been successfully building my docker image of node-red based on alpine for a couple weeks now, and I have an "update coreutils" in there before the build. Within the last couple days, the build no longer works and results in an error:
npm ERR! code ETARGET
npm ERR! notarget No matching version found for sentiment@2.1.1
npm ERR! notarget In most cases you or one of your dependencies are requesting
npm ERR! notarget a package version that doesn't exist.
npm ERR! notarget
npm ERR! notarget It was specified as a dependency of 'node-red-node-sentiment'
npm ERR! notarget
The full debug.log from a manual install of sentiment@2.1.1:
0 info it worked if it ends with ok
1 verbose cli [ '/usr/local/bin/node',
1 verbose cli '/usr/local/bin/npm',
1 verbose cli 'install',
1 verbose cli 'sentiment@2.1.1' ]
2 info using npm@6.4.1
3 info using node@v8.16.2
4 verbose config Skipping project config: /usr/src/node-red/.npmrc. (matches userconfig)
5 verbose npm-session d29c4d37a77aeb38
6 silly install loadCurrentTree
7 silly install readLocalPackageData
8 http fetch GET 304 https://registry.npmjs.org/sentiment 85ms (from cache)
9 silly registry:manifest no matching version for sentiment@2.1.1 in the cache. Forcing revalidation
10 http fetch GET 304 https://registry.npmjs.org/sentiment 22ms (from cache)
11 silly fetchPackageMetaData error for sentiment@2.1.1 No matching version found for sentiment@2.1.1
12 timing stage:rollbackFailedOptional Completed in 0ms
13 timing stage:runTopLevelLifecycles Completed in 680ms
14 verbose type version
15 verbose stack sentiment: No matching version found for sentiment@2.1.1
15 verbose stack at pickManifest (/usr/local/lib/node_modules/npm/node_modules/npm-pick-manifest/index.js:65:11)
15 verbose stack at fetchPackument.then.packument (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:52:18)
15 verbose stack at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
15 verbose stack at Promise._settlePromiseFromHandler (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:512:31)
15 verbose stack at Promise._settlePromise (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:569:18)
15 verbose stack at Promise._settlePromise0 (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:614:10)
15 verbose stack at Promise._settlePromises (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:693:18)
15 verbose stack at Async._drainQueue (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:133:16)
15 verbose stack at Async._drainQueues (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:143:10)
15 verbose stack at Immediate.Async.drainQueues (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
15 verbose stack at runCallback (timers.js:810:20)
15 verbose stack at tryOnImmediate (timers.js:768:5)
15 verbose stack at processImmediate [as _immediateCallback] (timers.js:745:5)
16 verbose cwd /usr/src/node-red
17 verbose Linux 3.10.0-957.el7.x86_64
18 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "sentiment@2.1.1"
19 verbose node v8.16.2
20 verbose npm v6.4.1
21 error code ETARGET
22 error notarget No matching version found for sentiment@2.1.1
23 error notarget In most cases you or one of your dependencies are requesting
23 error notarget a package version that doesn't exist.
24 verbose exit [ 1, true ]
Has anyone seen this problem? I'm not sure how to investigate or fix, and now I can't build my images so my development has come to a standstill.
