Serial Port control via button
I am using teensy 4.1 to communicate with node-red, which is actually sending a large stream of data. I would also want my serial port to receive data.
My sort of Idea to send "START" command to initially to serial port using button and then same port would send me stream of data. and "STOP" command with another button to stop flow of data. I am stuck with my buttons not responding.
        "id": "6ef4cd2b4815ca6f",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "Chart display ",
        "env": []
        "id": "b9b6c2061dd9470b",
        "type": "function",
        "z": "6ef4cd2b4815ca6f",
        "d": true,
        "name": "function 1",
        "func": " var dataArray = msg.payload.split(\",\");\n var x = parseFloat(dataArray[0]);\n var y = parseFloat(dataArray[1]);\n var z = parseFloat(dataArray[2]);\n\nvar formattedData = [{\n    \"series\": [\"x\", \"y\", \"y1\"],\n    \"data\": [[{ \"x\": x, \"y\": y, \"y1\": z}]],\n    \"label\": [\"\"]\n}];\n\n// Assign the formatted data to msg.payload\nmsg.payload = formattedData;\n\n// Return the modified message\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 720,
        "y": 40,
        "id": "5c112154cfdce7cb",
        "type": "function",
        "name": "Process Data",
        "func": "var dataArray = msg.payload.split(\",\");\nvar x = parseFloat(dataArray[0]);\nvar y = parseFloat(dataArray[1]);\nvar z = parseFloat(dataArray[2]);\n\nvar formattedData = {\n    dataset1: [{ \"x\": x, \"y\": y }],\n    dataset2: [{ \"x\": x, \"y\": z }]\n};\n\nmsg.payload = formattedData;\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 380,
        "y": 160,
                "ef6fa9b2.41d1d8"
        "id": "e4b0f7ec.d9cfd8",
        "type": "ui_button",
        "group": "7194439235dd2c51",
        "order": 2,
        "width": 2,
        "height": 2,
        "passthru": false,
        "label": "RUN/STOP",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "toggle",
        "payloadType": "str",
        "topic": "",
        "topicType": "str",
        "x": 150,
        "y": 100,
                "85f4b0a5.2d82b"
        "id": "85f4b0a5.2d82b",
        "type": "function",
        "name": "Control Serial",
        "func": "if (context.get('serialActive') === undefined) {\n    context.set('serialActive', false);\n}\n\nvar serialActive = context.get('serialActive');\n\nif (msg.payload === 'toggle') {\n    serialActive = !serialActive;\n    context.set('serialActive', serialActive);\n}\n\nif (serialActive) {\n    return [{payload: 'open'}, {payload: 'close'}];\n} else {\n    return [{payload: 'close'}, {payload: 'open'}];\n}",
        "outputs": 2,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 400,
        "y": 100,
        "id": "ef6fa9b2.41d1d8",
        "type": "ui_template",
        "order": 1,
        "width": 0,
        "height": 0,
        "format": "<div>\n  <canvas id=\"myChart\" width=\"400\" height=\"400\"></canvas>\n</div>\n<script src=\"https://cdn.jsdelivr.net/npm/chart.js\"></script>\n<script>\n  (function(scope) {\n    const initialData = {\n      datasets: [{\n        label: 'Current (I)',\n        data: [],\n        borderColor: 'rgba(255, 99, 132, 1)',\n        backgroundColor: 'rgba(255, 99, 132, 0.2)',\n        yAxisID: 'y',\n        parsing: {\n          xAxisKey: 'x',\n          yAxisKey: 'y'\n        }\n      }, {\n        label: 'Power (P)',\n        data: [],\n        borderColor: 'rgba(54, 162, 235, 1)',\n        backgroundColor: 'rgba(54, 162, 235, 0.2)',\n        yAxisID: 'y1',\n        parsing: {\n          xAxisKey: 'x',\n          yAxisKey: 'y'\n        }\n      }]\n    };\n\n    const config = {\n      type: 'line',\n      data: initialData,\n      options: {\n        responsive: true,\n        plugins: {\n          title: {\n            display: true,\n            text: 'SOLAR SIMULTAOR PLOT ',\n            font: {\n              size: 20\n            }\n          }\n        },\n        scales: {\n          x: {\n            type: 'linear',\n            position: 'bottom',\n            title: {\n              display: true,\n              text: 'Voltage (V)',\n              font: {\n                size: 16\n              }\n            }\n          },\n          y: {\n            type: 'linear',\n            display: true,\n            position: 'left',\n            title: {\n              display: true,\n              text: 'Current (I)',\n              font: {\n                size: 16\n              }\n            }\n          },\n          y1: {\n            type: 'linear',\n            display: true,\n            position: 'right',\n            grid: {\n              drawOnChartArea: false\n            },\n            title: {\n              display: true,\n              text: 'Power (P)',\n              font: {\n                size: 16\n              }\n            }\n          }\n        }\n      }\n    };\n\n    const myChart = new Chart(\n      document.getElementById('myChart'),\n      config\n    );\n\n    scope.$watch('msg.payload', function(payload) {\n      if (payload) {\n        myChart.data.datasets[0].data = payload.dataset1 || myChart.data.datasets[0].data;\n        myChart.data.datasets[1].data = payload.dataset2 || myChart.data.datasets[1].data;\n        myChart.update();\n      }\n    });\n  })(scope);\n</script>",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 540,
        "y": 160,
        "id": "e17b27fb.0fd95",
        "type": "function",
        "name": "Format to CSV",
        "func": "var timestamp = new Date().toISOString();\nvar dataArray = msg.payload.split(',');\nvar voltage = parseFloat(dataArray[0]);\nvar current \nvar csvData = `${timestamp},${dataArray.join(',')}`;\n\nreturn {\n    filename: 'F:\\Node-red files\\values.csv',\n    payload: csvData\n};",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 360,
        "y": 220,
                "9b2f4b5f.f54f68"
        "id": "9b2f4b5f.f54f68",
        "type": "file",
        "name": "Save to CSV",
        "filename": "/path/to/save/data.csv",
        "appendNewline": true,
        "createDir": false,
        "overwriteFile": "false",
        "encoding": "none",
        "x": 550,
        "y": 220,
        "id": "2e507f5d.1e8a2a",
        "name": "Start/Stop Recording",
        "order": 4,
        "width": 2,
        "height": 2,
        "passthru": false,
        "label": "Start Recording",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "topic": "",
        "topicType": "str",
        "x": 140,
        "y": 220,
                "e17b27fb.0fd95"
        "id": "534988724f245eea",
        "type": "serial in",
        "serial": "6d118033428a6ddb",
        "x": 170,
        "y": 160,
                "5c112154cfdce7cb",
                "e17b27fb.0fd95"
        "id": "633dd93a1d13c294",
        "type": "ui_spacer",
        "name": "spacer",
        "group": "33f05c93310ec062",
        "order": 1,
        "width": 12,
        "height": 1
        "id": "7f62f5bd1e8d72db",
        "name": "spacer",
        "order": 3,
        "width": 12,
        "height": 1
        "id": "f8d3482f047bd6ce",
        "name": "spacer",
        "order": 4,
        "width": 3,
        "height": 1
        "id": "486f516b33997d3a",
        "name": "spacer",
        "order": 5,
        "width": 7,
        "height": 1
        "id": "8e18e686c208c2ba",
        "name": "spacer",
        "order": 6,
        "width": 3,
        "height": 1
        "id": "83adaecf80503ee9",
        "name": "spacer",
        "order": 7,
        "width": 7,
        "height": 1
        "id": "3238ae01e93a545f",
        "name": "spacer",
        "order": 5,
        "width": 9,
        "height": 1
        "id": "90c934cfa154af21",
        "name": "spacer",
        "order": 6,
        "width": 9,
        "height": 1
        "id": "7194439235dd2c51",
        "type": "ui_group",
        "name": "SS",
        "tab": "b6867d794c44ccf6",
        "order": 1,
        "disp": true,
        "width": 15,
        "collapse": false,
        "className": ""
        "id": "6d118033428a6ddb",
        "type": "serial-port",
        "name": "Data Stream",
        "serialport": "COM11",
        "serialbaud": "9600",
        "databits": "8",
        "parity": "none",
        "stopbits": "1",
        "waitfor": "",
        "dtr": "none",
        "rts": "none",
        "cts": "none",
        "dsr": "none",
        "newline": "\\n",
        "bin": "false",
        "out": "char",
        "addchar": "",
        "responsetimeout": "10000"
        "id": "33f05c93310ec062",
        "type": "ui_group",
        "name": "Test Tab",
        "tab": "",
        "order": 1,
        "disp": true,
        "width": "12",
        "collapse": false,
        "className": ""
        "id": "b6867d794c44ccf6",
        "type": "ui_tab",
        "name": "Home",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
