Hello everyone .
Can anyone tell me why the server crashed?
as soon as I deploy this message appears to me.
Thanks in advance.
first time it happens to me
what should I do to restore normal operation
it happened after i was trying a counter library
Start node red in safe mode, search for server, remove it, deploy.
how do you start node-red in safe mode?
if you are not sure how to start in safe mode - as @Steve-Mcl suggested, the command is node-red --safe
Can you expand on that a bit. Did you import a flow or add or delete a node?
I imported a count node to make an hour counter then at some point the sever stopped.
Did you try startng in safe mode?
yes yes everything ok solved thanks a lot
