how to set document.title at runtime through a payload variable?
Is it somehow possible to call the angular function setTitle in an ui_template node?
Thanks,
Manuel
Thanks,
Manuel
This might help
Thanks for the hint but unfortunately I am not getting it.
So at least this test does not work out:
"id": "a95fc7a5.559d7",
"type": "ui_template",
"z": "912f241f.87cae8",
"group": "4a6429b4.097758",
"name": "setWindowTitle",
"order": 0,
"width": 0,
"height": 0,
"format": "<script>\n (function(scope) {\n scope.$watch('msg', function(msg) {\n if (msg) {\n $window.document.title = msg.payload;\n }\n });\n })(scope);\n</script>",
"storeOutMessages": true,
"fwdInMessages": true,
"templateScope": "global",
"x": 760,
"y": 200,
"aa7a0149.a3f72"
"id": "196f9a72.f381a6",
"type": "inject",
"topic": "",
"payload": "test",
"payloadType": "str",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 590,
"y": 200,
"a95fc7a5.559d7"
"id": "aa7a0149.a3f72",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 930,
"y": 200,
"id": "4a6429b4.097758",
"type": "ui_group",
"z": "",
"name": "test",
"tab": "a15e3d6a.2ebff",
"order": 2,
"disp": false,
"width": "10",
"collapse": false
"id": "a15e3d6a.2ebff",
"type": "ui_tab",
"z": "",
"name": "test",
"icon": "",
"order": 1,
"disabled": false,
"hidden": false
Well that's what I would have done probably so if it isn't working, I don't know why I'm afraid.
Put some console.log statements into the ui_template code to make sure you are getting what you expect and when. Also check your browser console to see if there are any errors.
The ui_template can't be targeted to site head but should be widget in the group.
And you don't have $window.document so use window.document instead
Thank you hotNipi, that was the trick.
I haven't been able to get this to work. @hotNipi do you have a sample flow I could import and try?
That same flow what was shared by @mj-123 works well if you apply those changes I mentioned.
I'm on the phone currently so no flow sharing for me...
Got it working. Thanks.
