Simple button / circle / square with value & colour change on dashboard
I know this is going to be super simple but after some help. I want to create a button / circle that has a payload value in eg temperatures and based on some greater than, less than rules I want to change its colour. Abit like the LED node, but I want the value on the button. May want the button to hyperlink to a url when pressed. Not bothered on exact shape.for now...more the function.
Anykne come across some good example?
Cheers,
Ant
Perhaps someone can give you some super simple example. Here would be my solution which is a bit more complicated:
        "id": "0ad0e4652ed2c5a9",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "67e5a02dc04c0c98",
        "type": "ui_template",
        "z": "0ad0e4652ed2c5a9",
        "group": "d921e9fe7b208126",
        "name": "button 3",
        "order": 3,
        "width": "2",
        "height": "4",
        "format": "<style>\n    .custom-button{\n        color:white!important;\n    }\n\n    .red{\n        background-color:red!important;\n    }\n\n    .green{\n        background-color:green!important;\n    }\n\n    .s36{\n        display:block;\n        vertical-align:unset;\n        width: 36px;\n        height: 36px;\n        filter:saturate(0.0) brightness(3.0) !important;\n    }\n    \n    .s36 md-icon{\n       \n    }\n</style>\n<button id=\"quadbutton\" class=\"{{quadcolor}} custom-button md-raised md-button md-ink-ripple\" type=\"button\" ng-click=\"OnButtonClick($event)\" aria-label=\"cloudbutton\">\n    <md-icon  class=\"s36\" md-svg-src='data:image/svg+xml;utf8,<svg xmlns=\"http://www.w3.org/2000/svg\" viewBox=\"0 0 616 512\"><path d=\"M148.6 304c8.2 68.5 67.4 115.5 146 111.3 51.2 43.3 136.8 45.8 186.4-5.6 69.2 1.1 118.5-44.6 131.5-99.5 14.8-62.5-18.2-132.5-92.1-155.1-33-88.1-131.4-101.5-186.5-85-57.3 17.3-84.3 53.2-99.3 109.7-7.8 2.7-26.5 8.9-45 24.1 11.7 0 15.2 8.9 15.2 19.5v20.4c0 10.7-8.7 19.5-19.5 19.5h-20.2c-10.7 0-19.5-6-19.5-16.7V240H98.8C95 240 88 244.3 88 251.9v40.4c0 6.4 5.3 11.8 11.7 11.8h48.9zm227.4 8c-10.7 46.3 21.7 72.4 55.3 86.8C324.1 432.6 259.7 348 296 288c-33.2 21.6-33.7 71.2-29.2 92.9-17.9-12.4-53.8-32.4-57.4-79.8-3-39.9 21.5-75.7 57-93.9C297 191.4 369.9 198.7 400 248c-14.1-48-53.8-70.1-101.8-74.8 30.9-30.7 64.4-50.3 114.2-43.7 69.8 9.3 133.2 82.8 67.7 150.5 35-16.3 48.7-54.4 47.5-76.9l10.5 19.6c11.8 22 15.2 47.6 9.4 72-9.2 39-40.6 68.8-79.7 76.5-32.1 6.3-83.1-5.1-91.8-59.2zM128 208H88.2c-8.9 0-16.2-7.3-16.2-16.2v-39.6c0-8.9 7.3-16.2 16.2-16.2H128c8.9 0 16.2 7.3 16.2 16.2v39.6c0 8.9-7.3 16.2-16.2 16.2zM10.1 168C4.5 168 0 163.5 0 157.9v-27.8c0-5.6 4.5-10.1 10.1-10.1h27.7c5.5 0 10.1 4.5 10.1 10.1v27.8c0 5.6-4.5 10.1-10.1 10.1H10.1zM168 142.7v-21.4c0-5.1 4.2-9.3 9.3-9.3h21.4c5.1 0 9.3 4.2 9.3 9.3v21.4c0 5.1-4.2 9.3-9.3 9.3h-21.4c-5.1 0-9.3-4.2-9.3-9.3zM56 235.5v25c0 6.3-5.1 11.5-11.4 11.5H19.4C13.1 272 8 266.8 8 260.5v-25c0-6.3 5.1-11.5 11.4-11.5h25.1c6.4 0 11.5 5.2 11.5 11.5z\"/></svg>'>\n    </md-icon>\n    <span>{{quadLabel}}</span>\n</button>\n<button id=\"circlebutton\" class=\"{{circlecolor}} custom-button md-fab md-raised md-button md-ink-ripple\" type=\"button\" ng-click=\"OnButtonClick($event)\" aria-label=\"cloudbutton\">\n    <md-icon  class=\"s36\" md-svg-src='data:image/svg+xml;utf8,<svg xmlns=\"http://www.w3.org/2000/svg\" viewBox=\"0 0 616 512\"><path d=\"M148.6 304c8.2 68.5 67.4 115.5 146 111.3 51.2 43.3 136.8 45.8 186.4-5.6 69.2 1.1 118.5-44.6 131.5-99.5 14.8-62.5-18.2-132.5-92.1-155.1-33-88.1-131.4-101.5-186.5-85-57.3 17.3-84.3 53.2-99.3 109.7-7.8 2.7-26.5 8.9-45 24.1 11.7 0 15.2 8.9 15.2 19.5v20.4c0 10.7-8.7 19.5-19.5 19.5h-20.2c-10.7 0-19.5-6-19.5-16.7V240H98.8C95 240 88 244.3 88 251.9v40.4c0 6.4 5.3 11.8 11.7 11.8h48.9zm227.4 8c-10.7 46.3 21.7 72.4 55.3 86.8C324.1 432.6 259.7 348 296 288c-33.2 21.6-33.7 71.2-29.2 92.9-17.9-12.4-53.8-32.4-57.4-79.8-3-39.9 21.5-75.7 57-93.9C297 191.4 369.9 198.7 400 248c-14.1-48-53.8-70.1-101.8-74.8 30.9-30.7 64.4-50.3 114.2-43.7 69.8 9.3 133.2 82.8 67.7 150.5 35-16.3 48.7-54.4 47.5-76.9l10.5 19.6c11.8 22 15.2 47.6 9.4 72-9.2 39-40.6 68.8-79.7 76.5-32.1 6.3-83.1-5.1-91.8-59.2zM128 208H88.2c-8.9 0-16.2-7.3-16.2-16.2v-39.6c0-8.9 7.3-16.2 16.2-16.2H128c8.9 0 16.2 7.3 16.2 16.2v39.6c0 8.9-7.3 16.2-16.2 16.2zM10.1 168C4.5 168 0 163.5 0 157.9v-27.8c0-5.6 4.5-10.1 10.1-10.1h27.7c5.5 0 10.1 4.5 10.1 10.1v27.8c0 5.6-4.5 10.1-10.1 10.1H10.1zM168 142.7v-21.4c0-5.1 4.2-9.3 9.3-9.3h21.4c5.1 0 9.3 4.2 9.3 9.3v21.4c0 5.1-4.2 9.3-9.3 9.3h-21.4c-5.1 0-9.3-4.2-9.3-9.3zM56 235.5v25c0 6.3-5.1 11.5-11.4 11.5H19.4C13.1 272 8 266.8 8 260.5v-25c0-6.3 5.1-11.5 11.4-11.5h25.1c6.4 0 11.5 5.2 11.5 11.5z\"/></svg>'>\n    </md-icon>\n    <span>{{circleLabel}}</span>\n</button>\n\n<script>\n    (function(scope) {\n        scope.quadcolor = \"red\";\n        scope.circlecolor = \"green\";\n        scope.circleLabel = \"none\";\n        scope.quadLabel = \"none\";\n        scope.InjectRipple = function() {\n            const circleinjector = angular.element('#circlebutton').injector();\n            const quadinjector = angular.element('#quadbutton').injector();\n            circleinjector.invoke(scope.AttachCirclebuttonToRipple,null,null);\n            quadinjector.invoke(scope.AttachQuadbuttonToRipple,null,null);\n        };\n        scope.AttachCirclebuttonToRipple = function($mdInkRipple){\n            $mdInkRipple.attach(scope, angular.element('#circlebutton'), { center: false });\n        }\n        scope.AttachQuadbuttonToRipple = function($mdInkRipple){\n            $mdInkRipple.attach(scope, angular.element('#quadbutton'), { center: false });\n        }\n        scope.OnButtonClick = function(evt){\n            switch(evt.currentTarget.id){\n                case \"circlebutton\":\n                    if(scope.circlecolor == 'green'){\n                        scope.circlecolor = 'red';\n                    }else{\n                        scope.circlecolor = 'green';\n                    }\n                    scope.send({payload: \"Circle Button clicked\"});\n                    break;\n                case \"quadbutton\":\n                    if(scope.quadcolor == 'green'){\n                        scope.quadcolor = 'red';\n                    }else{\n                        scope.quadcolor = 'green';\n                    }\n                    scope.send({payload: \"Quad Button clicked\"});\n                break;\n                default:\n                    break;\n            }\n        }\n        scope.InjectRipple();\n        \n        //handle arriving messages\n        scope.$watch('msg', function(msg) {\n            if(msg !== undefined && msg !== null){\n                try{\n                    switch(msg.topic) {\n                        case \"circlevalue\":\n                            scope.$applyAsync(function(){\n                                scope.circleLabel = msg.payload;\n                            });\n                        break;\n                        \n                        case \"quadvalue\":\n                            scope.$applyAsync(function(){\n                                scope.quadLabel = msg.payload;\n                            });\n                        break;\n\n                        default:\n                        break;\n                    }\n                }catch(err){\n                    console.error(err);\n                }\n            }\n        });\n    })(scope);\n</script>",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "nr-dashboard-button _md styled-button styled-template",
        "x": 840,
        "y": 380,
        "id": "a9efe2984828caf7",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "3",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 290,
        "y": 380,
                "7bde84b82e94f5ef"
        "id": "7bde84b82e94f5ef",
        "type": "function",
        "name": "function 1",
        "func": "const obj1 = {topic: 'circlevalue', payload:new Date().getSeconds()};\nconst obj2 = { topic: 'quadvalue', payload: new Date().getSeconds()};\n\nreturn [[obj1, obj2]];",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 540,
        "y": 380,
                "67e5a02dc04c0c98"
        "id": "d921e9fe7b208126",
        "type": "ui_group",
        "name": "Buttons",
        "tab": "d0d82445ef65a632",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "d0d82445ef65a632",
        "type": "ui_tab",
        "name": "ButtonDesign",
        "icon": "dashboard",
        "order": 3,
        "disabled": false,
        "hidden": false
