Sonoff TX 2 channel
I just installed a new Sonoff TX 2 channel switch, which I flashed with Tasmota. The MQTT topic is Metal.
I can turn the two channels on and off by the web server. I see in the console that the MQTT topic for
channel 1 is
Metal/POWER1.
channel 2 is
Metal/POWER2.
When I try to send these commands from node red, it always toggles POWER1, and not POWER2.
Anyone got this thing to work?
19:58:19 MQT: stat/Metal/RESULT = {"POWER1":"OFF"}
19:58:19 MQT: stat/Metal/POWER1 = OFF
19:58:27 MQT: stat/Metal/RESULT = {"POWER1":"OFF"}
19:58:27 MQT: stat/Metal/POWER1 = OFF
To switch you need to cmnd topic
cmnd/Metal/POWER2 ON
Yes. I had to manually inject this into MQTT. The google inject screwed up the command.
What is google inject?
