Looking at your query you can already now reduce your network traffic:
group.get.state includes volume, mutestate, playbackstate. So you don't need to query them separately.
See get state documentation
You might simplify your program as
a standalone player is always treated the same as a group.
you dont need to send "group" commands to the coordinator - any group member is also ok. node-red-contrib-sonos-plus does the routing for you automatically (only group commands, not player commands).
So it seems that you need: volume, mutestate for group and player, playbackstate, queue mode (shuffle, etc) and the content (group.get.trackplus) - that shoule be possible with events (without polling).
For changes regarding the SONOS queue I have to explore more.
Thanks for getting back, I'm slightly distracted with replacing my HC2 whole house heating with something I am building in NR. Once it's done I will come back to my floorplan, hopefully by then you can report back on how you when with the SONOS queue.
I'm looking forward to implementing more audio in my HA system later using your contrib!
just the album cover + station name, title, author if available
some control button and the group information
TV and playlists to choose my favorites fast
Stations -
Automation: My favorite station Arabelle provides nice music but terrible ads and news from 5 minutes before to after every 30 minutes - so I switch to amazon to avoid that.
You will find also some links to ALEXA and to the overiew dashboard page.
My heating panel has just gone live, so I now have some time to look at this.
Do I understand the following correctly?
You have created a new node called “Sonos events”
Each “Sonos events” node listens to a single player and you can configure what you are listening for within the node
Each additional thing to listen to, creates a new output on the node
You need to implement a unique “Sonos events” node per Sonos player i.e. there is no way to have one node listen to multiple players, or all players in your network
You have built the “Sonos events” node in a “light” way so that it does not spam the local network, and hopefully you could have many of these nodes running simultaneously in NR
EDIT: first off all, I am a wireshark noob, but it looks like the network I/O when using the “Sonos events” node is unmeasurable by the eye, where-as polling using the “Sonos Plus” node was increasing my I/O traffic by 4-5x for 4x players, making it impractical to use for 10+ players
You would expect the Sonos-Plus node to be used to control (send commands to) Players i.e. “Sonos events” is used to listen, “Sonos Plus” is used to control
EDIT: I had a little look and the node is a thing of beauty. It appears to have everything one would need… I’ll plug it into my floorplan and see how it works, but on the face of it, it’s fantastic!
My “so-called” value-add:
Name: the field loses its value, so the node is always labelled by the Player IP address; please fix this
The colour of the node – take this as you wish, but the orange is a little dark making it a little hard for my somewhat tired eyes to read the text. If you want to keep it dark I’d suggest changing the text to an off-white or else lighted it up a little e.g. turn the saturation down
Brilliant work hklages!!
At a minimum, you need to include a “buy-me-a-coffee” link somewhere.
right
right
right. hmmm - I take it on my list for extensions. Maybe a list as input for the player field.
right. For many events, you only need one node (group changes). Only player volume, player mutestate is relevant for a single player and maybe group player volume/mutestate is sufficient.
right - My intention is to move node-red-contrib-sonos-plus on the same platform as events and then merge them.
Is very much appreciated and implemented in 0.4.2. Should be available now.
Brilliant work hklages!! At a minimum, you need to include a “buy-me-a-coffee” link somewhere.
Thanks "buy me a coffee" is already there - donation-by me a cappuccino
