I have search but cant find any node red support for the SX1509 i2c module. I want to use the pwm function to expand my rpi io count and would like a simple node to set each of the pins on the module
Have you looked at the MCP23017 Port Expander ?
There are nodes for this chip
EDIT - PWM not so easy with 23017, however I have used these for PWM -
https://flows.nodered.org/node/node-red-contrib-iiot-rpi-pca9685
Hi I will have a look at them the reason I wanted to find out for the 1509 is because I have a few of them left over from an older project
