Nah, there will be an icon, a tooltip to say "there is a description" and a click event that triggers RED.sidebar.show('info'). I will see if there is a way to focus on the description in the Sidebar.
Too bad, I have to have write access to be assigned if my memory serves me well, but it's not important Thanks
I'm thinking of adding a "file-text" icon (in svg) above the node on the right
or in the upper right corner of the node?
Add a tooltip description to the icon (description available)
Add a "click" event on this icon which opens the Info Sidebar
Add a "reveal" to tell the user where to look - I see what you mean but how to highlight the description?
Yes please, along side the error triangle and blue circle.
Hmm, actually, to Nicks point, not so sure that is a good idea. Those are for live issues whereas this is "just" info. So bottom would probably be a lot better?
Just use a simple shape, that is less distracting anyway. A simple filled circle is sufficient, its location tells you what it is (along with colour for those with colour vision - which, of course, isn't everyone).
I think if anything it should be not dissimilar to the decorations we already use and be “part of” the modified, and error area we already have. Maybe like that page icon above but just the outline and solid yellow.
If you mean these decorations, I'm not so sure. None of these are clickable.
I think a link should have some sort of icon, a book, question mark or an italic i perhaps.
ps the red triangle is perfect, does anyone else find the colours of the other two a bit too bright?
And the corpulent square status "LED" hurts to look at; too big, too ugly.
My recommendation would be to start with something really simple like Dave says - it can always be enhanced later. But going the other way likely to be harder.
It really doesn't need much, this is and should be a simple enhancement not something complex.
This is going to take a few iterations to get the look right. As it stands, I cannot picture anything that wouldn't just add noise to the flow diagram. It would be better to mock up a few ideas, different variations, rather than trying to do a concrete implementation of something first.
