Info icon for nodes with description?
I don't document much in node red (or enough), but when I do, it's not easily visible. And because I do it so rarely, and perhaps I'm not alone here, I don't really expect to look for documentation. Which means any descriptions I add to a node is easily forgotten and not revisited as much as I should.
Would it be possible to have a small info icon/emblem somewhere on the node to notify that it got text in the description tab? Perhaps even make it optional toggle on/off per user. Of course GUI is easily cluttered and already quite busy at times, so take it with a grain of salt.
Noticed other nodes like inject got nice tiny symbols to indicate some details, like repeat.
This is just something I notice that is easy to forget and overlook.
See also this thread Special indication on nodes with description
Wow, thanks, already a plugin for it! Must try...
We also have this PR to the editor that adds the info icon to nodes; just undecided if we want to add it it not.
I'm using doc-red and it is super helpful in remembering which nodes/groups/flows have additional documentation. Not perfect perhaps but definitely useful.
Yeah it almost solves my entire problem. One minor inconvenience is that it also marks a a node if that is a subflow and the subflow has documentation (in the tab). I almost always document subflows, as their interface is reused and thus more important than any individual node.
Thanks for the commendation.
If it is not perfect yet, do you have any suggestions for improvement? :wink:
@ThingsTinkerer
If I understand you correctly, you have documentated your main subflow but don't want to see the documentation icon on the flow node in the workspace? If so, I will discuss that intern and am sure that we can find a solution here.
Nothing specific right now. I think that we sometimes see slight overlaps or misalignment. Not really surprising given the tightness of the visual layout of Node-RED. Obviously, further integration with NR's core might well improve that. I know how tricky such visual layouts can be though so please don't think I'm criticising. :slight_smile:
Awesome! The node red experience becomes even better.
