Hi, i try to install sqlite via manage palette, and the manage palette tab shows that sqlite is installed, but i don't see it in the list of node tabs. i try to intall it via command (npm install node-red-node-sqlite) on Win, but still nothing. Any help?
I see you have installed multiple sqlite nodes, they may be interacting. I suggest you remove them all except the one you want to use.
Also, have you installed sqlite on your windows computer?
I delete all sqlite nodes and than re-install them, successfully..
I try to install SQLite on my Win, but i receive this:
I watch from here
Where can be the problem?
What are the files in the folder?
sqldiff, sqlite3, sqlite3_analyzer
Are they in the c:/sql folder?
You might want to look at that guide for installing SQLite again
The picture i sent previously did not show the folder, that i'm in to ?
I fix it.
Thank you for showing my mistake!
Which is better for SQL GUI- SQLiteStudio or DBeaver?
You got me, I’m a Mac man
I understand.
Anyone have experiences with SQLiteStudio or DBeave for sensor data storage ?
@Martin10 I have used both. I prefer DBeaver because most of the things you will ever require are going to be already available as GUI options. For example i used it with PostGRES and it is way better than PGAdmin. I assume will be the same for you.
I dont understand your sensor data storage, I mean data is data. I used InfluxDB for timeseries databases, and couldnt find a good GUI tool.
But as far as relational databases go i think you can not go wrong with DBeaver.
Thank you!
Can we install DBeaver on RPI ? Or if we need GUI for SQLite we have to use another GUI software ?
Did you try a Google search?
Yes, but don't understand very much
I imagine that few, if any, here have used DBeaver, never mind installed it on a Pi and how to install it is nothing to do with node-red. You might be better on a DBeaver or Pi forum.
In what way is DBeaver relevant to sensor data storage with node-red?
SQLite is option in NR, but in order to use SQLite we have to install it first, right? So anyone who want to use it, first have to find a way to install it on his hardware (PC, RPI...). That's why, it occurred to me, that they will be people with that type of experience.
