Hey,
I have just installed Sqlite in node red on a raspberry via the pallete manager, but in node red it is not in the list? how is this possible? normal sql is is only in the list.
Hey,
Did it come up with any message when you were installing?
What does the log say?
When I add a flow with a sqlite node in it, it says that it found a uninstalled node called sqlite, in the pallet manager it says that sq-lite is installed
What is the full name of the node it says is installed? node-red-something probably.
Thanks for the great info, but I’d still like you to answer the questions I asked.
I'll let you know tomorrow morning at 7.am Amsterdam time
are you sure you have sqlite installed?
try sudo apt-get install sqlite3
SEe log
Start Node-RED
Once Node-RED has started, point a browser at http://127.0.0.1:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-start to start Node-RED again
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
5 Dec 13:38:45 - [info]
Welcome to Node-RED
5 Dec 13:38:45 - [info] Node-RED version: v0.19.4
5 Dec 13:38:45 - [info] Node.js version: v8.11.1
5 Dec 13:38:45 - [info] Linux 4.14.79-v7+ arm LE
5 Dec 13:38:51 - [info] Loading palette nodes
5 Dec 13:39:06 - [info] Dashboard version 2.11.0 started at /ui
5 Dec 13:39:10 - [warn] ------------------------------------------------------
5 Dec 13:39:10 - [warn] [node-red-node-sqlite/sqlite] Error: Cannot find module '/home/pi/.node-red/node_modules/node-red-node-sqlite/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node'
5 Dec 13:39:10 - [info] Settings file : /home/pi/.node-red/settings.js
5 Dec 13:39:10 - [info] Context store : 'default' [module=memory]
5 Dec 13:39:10 - [info] User directory : /home/pi/.node-red
5 Dec 13:39:10 - [warn] Projects disabled : editorTheme.projects.enabled=false
5 Dec 13:39:10 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
your credentials.
5 Dec 13:39:10 - [info] Waiting for missing types to be registered:
5 Dec 13:39:10 - [info] - sqlite
5 Dec 13:39:10 - [info] Server now running at http://127.0.0.1:1880/
5 Dec 13:40:11 - [info] Stopping flows
5 Dec 13:40:11 - [info] Stopped flows
5 Dec 13:40:11 - [info] Waiting for missing types to be registered:
5 Dec 13:40:11 - [info] - sqlite
pi@raspberrypi:~ $ sudo apt-get install sqlite3
Reading package lists... Done
Building dependency tree
Reading state information... Done
sqlite3 is already the newest version (3.16.2-5+deb9u1).
0 upgraded, 0 newly installed, 0 to remove and 33 not upgraded
> sqlite is already the newest version (2.8.17-14).
> 0 upgraded, 0 newly installed, 0 to remove and 33 not upgraded.
so now
cd .node-red
and the install the node and look at the messages for any errors.
There are no errors, the node is installed without errors
Just to confirm you have installed the node again, from within your .node-red directory?
I'm installing it with this code: "sudo apt-get install sqlite3", after it says in the pallete manager that it's installed, but it's not showed in the list and giving the error when I import a flow with a sqlite node in it.
I don't know what to do
But thats not the node-red-node.
With that you have installed the "database", but now that is installed you need to reinstall the Node-RED component that allows you to read and write to that "database".
See this page for how to do it.
NOTE It does not use sudo
If that install fails due to not having access type errors, then try it with extra parameter
npm i —unsafe-perm node-red-node-sqlite
Fixed it with some help https://groups.google.com/forum/#!topic/node-red/60STlYN53e0
