Sqlite3 not installed or broken
I've been trying to do reindex on my db but nothing happens when I run it through the node-red.
So I tried to do it through shell, but seems there is no sqlite3 installed.
Which is weid because node-red-node-sqlite works OK:
Also, there is this issue in /node_modules:
Here are some querry listings:
pi@odin:~ $ sqlite3
-bash: sqlite3: command not found
pi@odin:~ $ npm list node-red-node-sqlite
/home/pi
└── node-red-node-sqlite@1.0.1
pi@odin:~ $ npm list sqlite3
/home/pi
└─┬ node-red-node-sqlite@1.0.1
  └── UNMET DEPENDENCY sqlite3@5.0.2
npm ERR! missing: sqlite3@5.0.2, required by node-red-node-sqlite@1.0.1
pi@odin:~ $ dpkg -l | grep sqlite3
iU  libaprutil1-dbd-sqlite3:armhf        1.6.1-4+deb10u1                         armhf        Apache Portable Runtime Utility Library - SQLite3 Driver
ii  libsqlite3-0:armhf
pi@odin:~ $ apt show sqlite3
Package: sqlite3
Version: 3.27.2-3+deb10u2
Priority: optional
Section: database
Maintainer: Laszlo Boszormenyi (GCS) <gcs@debian.org>
Installed-Size: 2,278 kB
Depends: libc6 (>= 2.28), libreadline7 (>= 6.0), zlib1g (>= 1:1.2.0), libsqlite3-0 (= 3.27.2-3+deb10u2)
Suggests: sqlite3-doc
Homepage: https://www.sqlite.org/
Download-Size: 839 kB
APT-Sources: http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
Description: Command line interface for SQLite 3
 SQLite is a C library that implements an SQL database engine.
 Programs that link with the SQLite library can have SQL database
 access without running a separate RDBMS process.
Anyone know how to fix it?
Debian 10 buster
Node-red 2.14
Node 14
Assuming that you have a conventional install of node-red then you must do that from within your .node-red folder. For some reason it seems you have been installing nodes into your home folder. Possibly by running npm install from there.
It is not weird, node-red-node-sqlite includes its own driver, the command line utility does not have to be installed. If you want to use it then install it using apt.
