Stop node red at boot
So, I understand how to start node red in safe mode but how do I get in front of node red on boot? It is set to start up at boot from systemctl and when node red starts it crashes the Pi. I know what I did wrong but I can't figure out how to get in front of node red on boot.
Pi 4 running PI OS
thanks
If you can get at the card contents, in a USB SD card reader, or maybe init=/bin/sh, then deleting /etc/systemd/system/multi-user.target.wants/nodered.service is equivalent to systemctl disable nodered
I think I have a card reader somewhere, I'll have to go hunt for it
So.... got a card reader and put into my Windows machine and I assume I can't read the Linux / Pi OS file system because there isn't anything resembling that file path on the card
just to complete the loop, google showed lot's of software I could get for free to read linux files, anything free I'm immediately suspicious, so I reformated the sd and reinstalled.
Thanks for the thoughts and help
Here are a couple of options.
Access to Ext 2/3/4, HFS and ReiserFS from Windows| DiskInternals
Windows 10 Ubuntu Bash Shell: How Do I Mount Other Windows Drives? - Super User
Get started mounting a Linux disk in WSL 2 | Microsoft Docs
If you have WSL, you should be able to access ext formatted sd-card partitions. That last link is from Microsoft docs.
Too late now but:
You can boot a Windows pc from a linux live CD/dvd/usb drive without installing anything on the PC.
With a spare Raspbian SD card you could do it from the Pi.
It's a complete mystery why Microsoft would go to the effort of providing a Linux shell for Windows 10 and still not provide ext4 disk support.
"Not invented here" disease maybe.
A spare rpi is always good to have in this kind of situations, just plugin a usb sd card reader with the faulty setup, you should then find it under /media
