Strange editor UI labellings
An interesting UI phenominon after updating to v4.0.9.
I have found no information via Googling, and am not even
certain exactly how I would research it properly-!
Happening on a Nanopi Fire 3, a raspberry pi 4 and a Windows 10 PC.
It is apparently not destabilizing, just visually peculiar
as I've never seen the phenomenon occur before,
and am wholly uncertain of how to correct it
before I pursue any further edge device updates.
Any ideas / recommendations / advice?
Did you have refreshed your browser?
Yes, caches cleared and visited from other physical Internet locations with Chrome, Chromium and Edge, all with the same result - it is text being served by various updated Node-RED installs.
Is this only happening on the Dashboard sidebar, or also elsewhere too?
Erm, not sure what I am supposed to be looking at here, my Dashboard 2 sidebar looks exactly the same?
I have seen that too in the dashboard sidebar, but do not have access to my PC at the moment to investigate.
DB 1.24.2
NR 4.0.9 & 4.1
Same issue. Only related to DB2 Sidebar.
@joepavitt, ui_template must be replaced by ui-base
All three affected edge devices apparently exhibit the phenomenon only in the sidebar.
I am facing the same - since last DB2 upgrade.
DB2 1.24.0
NR is 4.0.9
In addition the titles on the dashboard widgets got corrupted. See below snapshot. This is happening across multiple widgets - forms / dropdown.
This is now causing serious issues where the dashboard becomes unusable - since user unable to understand the the titles. (esp. on forms with multiple fields)
This was fixed in latest version.
This is not latest version
Great.
I am aware. Reporting it late. The issue cropped up since 1.24.0 and i have not seen anything in RN of 1.24.1 / .2 saying its fixed. So was not sure.
Would you know if its fixed in latest version ? Then i can upgrade and test.
You posted a quote from Steve at the start of your reply, saying that it is fixed.
Link to release notes for v1.24.1
