Dashboard 2.0 tab in editor sidebar is showing label names instead of the label values
I have been seeing this for a while but wondered if there is an open ticket or if it something wrong with my setup.
When I open the Dashboard 2.0 tab in the editor sidebar all of the labels in the tab are displayed by name rather than their value
running node red v4.1.0-beta.2 and @flowfuse/node-red-dashboard 1.25.0
Open issue: ui_template.label.layout Issue · Issue #1710 · FlowFuse/node-red-dashboard · GitHub
Can you look in the devtools, network tab, see if there was any issue downloading the resources?
I'm not seeing anything but I am not sure I have done this right
After opening devtools you should F5 refresh the page. That's the only way to see if assets are fetched.
I see the same thing on various Pies with different DB2 versions.
One of them though did not show the issue either before or after I updated DB2 from 1.24.0 to 1.25.0.
This NR installation only has NR 4.0.9, DB2 1.25.0 & cron-plus 2.1.0
The others have a lot more nodes installed.
I have added a comment to the issue, no problems seen in the developer tools. Also I checked that clearing the browser cache did not help.
