Hi there, I'm using the transform animation from SVG-ui node to make some objects move linearly. Everything works great. However, now I need to make a curved animation. I know that there is a property for SVG of motion animation, in which the object follows a path. Is there a way to perform a curved animation in SVG UI?
HI @thalesmaoa,
Currently the "Animation" tabsheet of the ui-svg node does not support curved animations.
Of course you can always add animations yourself to the svg, in this case an animateMotion animation element (see example here). The disadvantage - compared to the "Animation" tabsheet, is that you can only edit your drawing with an external svg editor that supports animations. I have never looked at that, so I cannot give any advice about this.
Bart
