Switch with window / door (open / close) Customize icon or create it yourself?
I want to customize a switch for an application. I need windows and door (open / close). Unfortunately I can not find this icon in the database. I can integrate all other icons (including color and size).
Can you customize an icon yourself and directly on the calculator
store (for example, raspberry)?
I turn on a GPIO IN with Red relay and then want to see the state (open / close).
Does somebody has any idea?
Many Thanks
Thoralf
I have used the folder open and closed icons rotated by 90 degrees ( fa-rotate-90 ) before now... not ideal but not too bad.
Thanks for your tip. It does not look so bad.
If I get stuck, I'll use it that way too.
It does not seem to be that easy to work with yourself.
I am surprised only because this Icon certainly a lot in practice
much needed.
many Greetings
Thoralf
