Hello dear Comunity,
I have another problem with a timeloop. I have 6 switching outputs that should be switched in a loop with adjustable time on and pause in a loop. The logic is as follows:
Via UI setting switching time (t_on) on for outputs (DO) and pause(t_break) and start/stop.
After start
DO1 TRUE while t_on, all DO FALSE while t_break
DO2 TRUE while t_on, all DO FALSE while t_break
DO6 TRUE while t_on, all DO FALSE while t_break
I don't have a clever solution yet to implement this in Node-Red - thank you!
