Добрый вечер, я новенький в использовании node red, подскажите пожалуйста как я мог создать узлы для подключеение и создание запроса в базу данных Sybase iq.
Буду очень благодарен если будет пример обращенния в Sybase iq. извините если за мой английский.
Good evening, I'm new to using node red, please tell me how I could create nodes for connecting and creating a query to the Sybase iq database.
I would be very grateful if there would be an example of circulation in Sybase iq. sorry if for my english.
I don't know Sybase IQ at all - but it seems like it may be an SQL database so one of the nodes on flows.nodered.org that handles sql may be able to connect.
Here is my workflow, if I need to integrate something new into Node-RED:
search in the flow library for existing nodes
in many cases someone has already written something you can use -
search at NPM
- look for node-red nodes, some are not listed in flows.nodered.org
- look for NodeJS libraries: I came up with https://www.npmjs.com/package/sybase
From there you have two choices:
- integrate the library in your settings.js in
functionGlobalContextand use it in a function node - wrap the library in a new node by following the docs
(and hopefully share it with the community)
I would recommend the latter, if there is some more complex client state handling involved (connections, etc...)
