Systems Variable for functionName?
Is there a systems variable with which to read the function name from which it was called? (in a function).. ?
I think that you need to explain more about what you are trying to achieve.
Ahhh, sorry,
want to create error trapping - want to send errors to a database, with some fields, like what was the incoming topic, messafge, error code, and from which function it came, want to sue same code in multiple functions, thus want a systems variable in the error trapping code that includes the function name it came from.
The catch node can give you some details in msg.error object.
I do this for logging to file by extracting what I need from the error object.
Have a look at the docs that tell what variables are defined in the Function node: https://nodered.org/docs/user-guide/writing-functions#api-reference
