I'm using a table node to display information per device. The information comes in async and I add it to the array of objects then send to the table. The flow is below. The table will only display the 1st entry.
[{"id":"592c7363.cac7bc","type":"tab","label":"Remote Manager","disabled":false,"info":""},{"id":"9161c566.8fa468","type":"switch","z":"592c7363.cac7bc","name":"Beacon messages","property":"type","propertyType":"msg","rules":[{"t":"eq","v":"Mtype_Beacon_Msg_unAssigned","vt":"global"}],"checkall":"true","repair":false,"outputs":1,"x":370,"y":140,"wires":[["5dbf41e0.07f578"]]},{"id":"aff73007.c147b","type":"link in","z":"592c7363.cac7bc","name":"","links":["e4f2e4f1.d2d76"],"x":215,"y":140,"wires":[["9161c566.8fa468"]]},{"id":"e7cf42ae.907a08","type":"comment","z":"592c7363.cac7bc","name":"Unassigned Beacons","info":"","x":500,"y":80,"wires":[]},{"id":"76c771fc.49e988","type":"buffer-parser","z":"592c7363.cac7bc","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"uint8","name":"DevType","offset":5,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"state","offset":6,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"biguint64le","name":"UNI","offset":7,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":790,"y":140,"wires":[["49a6b83d.fe947","52954531.d20804"]]},{"id":"49a6b83d.fe947","type":"function","z":"592c7363.cac7bc","name":"","func":" \n\nvar remotes=flow.get(\"remotes\") || []\n var DevTypes = global.get(\"DevTypes\")\n \n var temp ={}\n \n var i,length\n\n var found = false\n \n length = remotes.length\n \n for (i = 0; i < length; i++)\n {\n if (msg.payload[2].toString(16) == remotes[i].UNI)\n {\n found=true\n break;\n }\n }\n \n if (found == false)//add new remote\n {\n \n temp.DevType = DevTypes[msg.payload[0]]\n \n if (msg.payload[1] & 0x80)\n {\n temp.state=\"Reset\"\n }\n else\n {\n temp.state= \"Normal\"\n }\n \n \n temp.UNI = msg.payload[2].toString(16)\n remotes[i]=temp\n node.warn(remotes)\n flow.set(\"remotes\",remotes)\n msg.payload = remotes\n return msg;\n}","outputs":1,"noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\n\nflow.set(\"remotes\",null)","finalize":"","libs":[],"x":1000,"y":140,"wires":[["c4f802ef.ec8f48","52954531.d20804"]]},{"id":"5dbf41e0.07f578","type":"buffer-maker","z":"592c7363.cac7bc","name":"","specification":"spec","specificationType":"ui","items":[{"name":"item1","type":"uint8","length":17,"dataType":"msg","data":"payload"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":610,"y":140,"wires":[["76c771fc.49e988"]]},{"id":"c4f802ef.ec8f48","type":"ui_table","z":"592c7363.cac7bc","group":"5513dab1bcfcbacb","name":"","order":1,"width":9,"height":12,"columns":[{"field":"DevType","title":"DevType","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"state","title":"State","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"UNI","title":"UNI","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}}],"outputs":0,"cts":false,"x":1230,"y":140,"wires":[]},{"id":"38a92c0d.39304c","type":"inject","z":"592c7363.cac7bc","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":670,"y":60,"wires":[["5c3475df.e9976c"]]},{"id":"5c3475df.e9976c","type":"function","z":"592c7363.cac7bc","name":"","func":"msg.payload=[]\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":960,"y":60,"wires":[["c4f802ef.ec8f48"]]},{"id":"52954531.d20804","type":"debug","z":"592c7363.cac7bc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1190,"y":220,"wires":[]},{"id":"5513dab1bcfcbacb","type":"ui_group","name":"Unassigned Remotes","tab":"8bad4a75.48931","order":1,"disp":true,"width":9,"collapse":false,"className":""},{"id":"8bad4a75.48931","type":"ui_tab","name":"Remotes Manager","icon":"dashboard","disabled":false,"hidden":false}]type or paste code here
Something very similar to this works fine in another flow. What am I missing?
