I post this here in case someone has similar problems and wants to save a lot of time and aggravation (like it has been my experience).
I had a few remote machines with logs I had to control, some running linux CentOS, some running Windows (W7 and XP).
As pointed out in previous messages, the Tail node does not support monitoring remote files, so for the Linux machines, I mounted the log file folder in my node-red server with NFS and set up the following flow with the execution node:
The command being run in the execution node is:
tail -f -n 1 <full file path>
The loop backwards with the 60 second delay picks up any error code being thrown and forces a retry. I could have used the -F option (follow with retry), but that won't throw errors, just wait for the file to be available. This way allows me to get debug output (if needed).
This went smooth, and allowed real-time log monitoring (or as close to it as it comes).
Now, for the Windows machines, I had to mount the log folders with Samba. I realised that if I used the same setup, the tail command would lock the file and the machine would not be able to write new lines to the log files.
I tried then copying the log files I needed from the mounted folders to a local folder, and monitoring them there. The issue here is that cp would overwrite the file, and the tail command (with the exec node, as seen earlier) would resend all the files every time the file was overwritten.
I solved this by setting up two separate flows: one to update the log files in the local folder, one to monitor those files.
In a similar flow setup, I used an execute node to update the files, with a 60 second retry in case there's any error code:
The full command being run is:
rsync -t --inplace --no-whole-file <remote file full path> <local file path>
- The -t option will preserve the file's timestamp, so I can see when the file was last updated instead of the time when I synced it.
- The --inplace --no-whole-file options will ensure that the new lines since last update are added to the end of the file, and that only the new lines are written (no duplicates).
With this done, I just used the regular Tail node on the local files, sending one message per line, and then process them (inserting each line on a MySQL DB, in my case, for information processing).
I hope this is of use.
