Tail Node path issue (Noob)
Hi, (warning, huge nood ahead!)
I've got Node-Red set up with Home Assistant (through the supervisor). It has allowed me to create a bunch of great automations so far.
Currently I'm trying to read a log file 'OZW_Log.txt' to get granular Z-Wave data.
From what I can tell I should be able to point a Tail Node at that file... but I can't get the Tail Node to find any files. (I get this debug info: "File not found: <any path I've tried>")
This is running on a Synology NAS with docker. Below are the relevant system paths:
/volume1/docker/hass.io/homeassistant/OZW_Log.txt
/volume1/docker/hass.io/homeassistant/node-red
I'm sure I'm missing something obvious, but I can't seem to figure it out, and I haven't found any info besides some volume mounting info that's going a little over my head, and I didn't want to start messing around randomly with the docker config given that the rest of node-red is currently working.
Thanks in advance for reading, and hopefully pointing me in the right direction here. lol.
As you are running node-red in a docker container, you cannot access the native filesystem (it is a container, hence the word container)
You should be able to open the file like ./OZW_Log.txt
Or if that doesn't work, use an exec node to determine which directory node-red is living on with pwd
Thanks for the reply!
I figured it out after playing with things for a bit again using your suggestion.
I found this list of volumes in the container details:
So, I just had to use: /config/OZW_Log.txt
It's reading out the file now, so now I can get to automating more things!
Thanks!
