Hi there,
after a longer time I want to make some adjustments to my Telegram connection. For test, I have just connected a receiver and sender and a debug pad.
It receives /responds only messages starting with a "/" - why this?
Also, when using a switch node and set msg.payload.content contains "/ccc" for instance, the switch does not give an output.
please help!
In the meantime i found, that it dies respond, when it receives the message directly, but not from a chat group (what I tried first)..
