Hi, my Telegram Switch gives the following error:
received callback in 2939***** from 'undefined' was unauthorized
Can you help correct it please?
[{"id":"3ea557b1.e7fec8","type":"tab","label":"Teste","disabled":false,"info":"Pagina de testes."},{"id":"ade16afc.ec8a48","type":"stoptimer","z":"3ea557b1.e7fec8","duration":"20","units":"Second","payloadtype":"num","payloadval":"0","name":"10min","x":270,"y":100,"wires":[["c7d87221.bd2dc"],[]]},{"id":"c7d87221.bd2dc","type":"telegrambot-switch","z":"3ea557b1.e7fec8","name":"","bot":"8b22b70c.466fd8","chatId":"293995835","question":"Pretendes Desligar a Luz?","answers":["Sim","NĂŁo"],"outputs":2,"autoAnswerCallback":true,"timeoutValue":"","timeoutUnits":"","x":420,"y":100,"wires":[["fe1316ae.dfcd88"],["832e6b5b.d66768"]]},{"id":"f69a1174.d968b","type":"server-state-changed","z":"3ea557b1.e7fec8","name":"Luz Exteriror ON","server":"3e05aa42.de7f36","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"light.luz_exterior","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is_not","outputs":2,"output_only_on_state_change":true,"x":100,"y":100,"wires":[[],["ade16afc.ec8a48"]]},{"id":"fe1316ae.dfcd88","type":"api-call-service","z":"3ea557b1.e7fec8","name":"Luz Exterior OFF","server":"3e05aa42.de7f36","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.luz_exterior","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":610,"y":80,"wires":[["16683a6e.cdb636"]]},{"id":"16683a6e.cdb636","type":"telegrambot-notify","z":"3ea557b1.e7fec8","name":"","bot":"8b22b70c.466fd8","chatId":"293995835","message":"Luz Exterior, Desligada !","parseMode":"","x":820,"y":80,"wires":[]},{"id":"832e6b5b.d66768","type":"telegrambot-notify","z":"3ea557b1.e7fec8","name":"","bot":"8b22b70c.466fd8","chatId":"293995835","message":"Luz Exterior, Continua Ligada !","parseMode":"","x":600,"y":120,"wires":[]},{"id":"8b22b70c.466fd8","type":"telegrambot-config","z":"","botname":"Daisy","usernames":"Pedro","chatIds":"","pollInterval":"300"},{"id":"3e05aa42.de7f36","type":"server","z":"","name":"Home Assistant"}]
What you want is to be notified by Telegram when I forget a light on.
Receive a two-option message to remain on or off.
For this I used a telegram switch. I get the message on my phone.
But when answering it does not perform the functions.
And in Node-RED the following error appears:
received callback in 293***835 from 'undefined' was unauthorized
The switch on node-RED is in the state: "Waiting for reply".
Help me please !
Okay, based on the image of the flow youâre using the home assistant nodes with https://flows.nodered.org/node/node-red-contrib-telegrambot-home
I donât know what that timer node is, but it looks like a contrib delay like node.
The telegrambot-home nodes say that the included switch node sends a message over telegram to the configured user to ask a question, and route the message based on the user response. Have you checked the settings in the switch node to make sure the authentication is set up correctly? Check the token with Botfather to verify itâs correct. And make sure youâve the right chat id too.
This issue is closed/fixed, but offers another insight. Check that your username is set as authorised to communicate with the bot: https://github.com/scraton/node-red-contrib-telegrambot-home/issues/12
Yes, but based on the error your account, as in you pressing the button, is read as âundefinedâ. And undefined isnât authorised in the settings. Either youâre seeing a bug in the node, or something in your configuration is askew.
My question is how to add my ID to the authorized list.
Can you help? Please
Can you show the config node for the telegram bot, specifically the field âUsersâ? Ah found it in your flow. Did you confirm this matches your telegram username exactly?
If yes, file an issue on the nodeâs github
Yes. Is your telegram username âPedroâ (username, not display name)? If yes, file a bug. If no, change it to your username. Usernames in the Users field are considered authorised to interact with the bot.
No, thatâs your display name.
That is the user with username Pedro.
By default you donât have a username until you set it up in your account settings.
Which also explains why the node gives undefined as your username: you donât have one at the moment.
I got the name "Pedro", I just left the CHAT ID, it worked!
Thank you for your help !
