Template Node (array integration)
Hi all,
Having trouble grabbing values from an array using the template node. I did some skimming on google but didn't find a real clear answer. Seen a bunch of "Attach it to a debug node and look for the results..."
This is what is coming out of my join node as an array:
{"_msgid":"21936ce2.9c0954","topic":"","payload":["2019-08-19T23:00:00-05:00","2019-08-20T24:00:00-05:00"]}
However when passing it to a template node:
Template Node code:
start={{payload.[1]}}
Template Node Output:
{"_msgid":"21936ce2.9c0954","topic":"","payload":"start="}
I do something similar with a function node and get the expected result. I prefer to use the template node for simplicity if possible. If not, not a biggie.
Thanks, Matt
Try
start={{payload.1}}
-- Mike
@mike Does the template node prefer JSONanata like syntax for accessing elements? :thinking: Didn’t know that trick, thanks
No. Its mustache syntax in the template node
Thanks Mike.
