Tensorflow coco SSD
Hi
I've updated today node-red as well as the node "node-red-contrib-tfjs-coco-ssd" (to the latest version 1.0.2). After deploying the flow I get this error:
nodered
Anyone an idea what this means? The system is running on a Raspberry PI 3.
Thank you. Best regards
Did you update node js?
If yes, then either npm rebuild or try uninstall/reinstall that node.
Hi, I used this command from this website: Running on Raspberry Pi : Node-RED
So normally it should update also node js or am I wrong?
I've already tried to uninstall/reinstall the node, without success.
What you mean by "npm rebuild"?
Make sure you also uninstall the @tensorflow/tfjs libraries. You may need to do this manually from the node_modules directory after uninstalling the node.
