Text wrap in node-red-contrib-ui-multistate-switch
A new version of node-red-contrib-ui-multistate-switch has been released recently. Although better I miss the text wrap it had in the previous releases, like this:
Bart, could you consider a flag allowing text wrap?
Noted, but would you please rise an issue at the github page. One line and multi-line label should then be properly managed cases and it affects whole layout. It needs to be discusses when @BartButenaers is back in business.
Thank you.
