The buttons in/on the edit screen
Next (dumb) question:
Change to the Node-RED userDir directory, usually ~/.node-red
Change (to me) usually has a from and to part.
This doesn't.
Change it..... to from what?
Just means make sure you are in your "default" NR directory. The same one you use when installing nodes. This is basically just another node that needs installing.
Yeah, ok. My bad. change as in cd /home/(yourname)/.node-red
Gotocha.
Still not working. :frowning:
Bog standard edit screen.
Node-red has been stopped, started and restarted. No change to the screen.
SHIFT REFRESH. No change.
Opened in private window (browser - no cookies etc) No change. Bog standard white screen.
Can you show your settings.js file?
With appropriate negations.
 * Copyright JS Foundation and other contributors, http://js.foundation
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 * http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
// The `https` setting requires the `fs` module. Uncomment the following
// to make it available:
//var fs = require("fs");
module.exports = {
    // the tcp port that the Node-RED web server is listening on
    uiPort: process.env.PORT || 1880,
    // By default, the Node-RED UI accepts connections on all IPv4 interfaces.
    // The following property can be used to listen on a specific interface. For
    // example, the following would only allow connections from the local machine.
    //uiHost: "127.0.0.1",
    // Retry time in milliseconds for MQTT connections
    mqttReconnectTime: 15000,
    // Retry time in milliseconds for Serial port connections
    serialReconnectTime: 15000,
    // Retry time in milliseconds for TCP socket connections
    //socketReconnectTime: 10000,
    // Timeout in milliseconds for TCP server socket connections
    //  defaults to no timeout
    //socketTimeout: 120000,
    // Timeout in milliseconds for HTTP request connections
    //  defaults to 120 seconds
    //httpRequestTimeout: 120000,
    // The maximum length, in characters, of any message sent to the debug sidebar tab
    debugMaxLength: 1000,
    // The maximum number of messages nodes will buffer internally as part of their
    // operation. This applies across a range of nodes that operate on message sequences.
    //  defaults to no limit. A value of 0 also means no limit is applied.
    //nodeMaxMessageBufferLength: 0,
    // To disable the option for using local files for storing keys and certificates in the TLS configuration
    //  node, set this to true
    //tlsConfigDisableLocalFiles: true,
    // Colourise the console output of the debug node
    //debugUseColors: true,
    // The file containing the flows. If not set, it defaults to flows_<hostname>.json
    //flowFile: 'flows.json',
    // To enabled pretty-printing of the flow within the flow file, set the following
    //  property to true:
    //flowFilePretty: true,
    // By default, credentials are encrypted in storage using a generated key. To
    // specify your own secret, set the following property.
    // If you want to disable encryption of credentials, set this property to false.
    // Note: once you set this property, do not change it - doing so will prevent
    // node-red from being able to decrypt your existing credentials and they will be
    // lost.
    //credentialSecret: "a-secret-key",
    // By default, all user data is stored in the Node-RED install directory. To
    // use a different location, the following property can be used
    //userDir: '/home/nol/.node-red/',
    //userDir: '/home/me/.node-red/',
    // Node-RED scans the `nodes` directory in the install directory to find nodes.
    // The following property can be used to specify an additional directory to scan.
    //nodesDir: '/home/nol/.node-red/nodes',
    // By default, the Node-RED UI is available at http://localhost:1880/
    // The following property can be used to specify a different root path.
    // If set to false, this is disabled.
    //httpAdminRoot: '/admin',
    // Some nodes, such as HTTP In, can be used to listen for incoming http requests.
    // By default, these are served relative to '/'. The following property
    // can be used to specifiy a different root path. If set to false, this is
    // disabled.
    //httpNodeRoot: '/red-nodes',
    // The following property can be used in place of 'httpAdminRoot' and 'httpNodeRoot',
    // to apply the same root to both parts.
    //httpRoot: '/red',
    // When httpAdminRoot is used to move the UI to a different root path, the
    // following property can be used to identify a directory of static content
    // that should be served at http://localhost:1880/.
    //httpStatic: '/home/nol/node-red-static/',
    httpStatic: '/home/me/.node-red/public',
    // The maximum size of HTTP request that will be accepted by the runtime api.
    // Default: 5mb
    //apiMaxLength: '5mb',
    // If you installed the optional node-red-dashboard you can set it's path
    // relative to httpRoot
    //ui: { path: "ui" },
    // Securing Node-RED
    // To password protect the Node-RED editor and admin API, the following
    // property can be used. See http://nodered.org/docs/security.html for details.
    //  Put new password stuff here.
    //adminAuth: {
    //    type: "credentials",
    //    users: [{
    // To password protect the node-defined HTTP endpoints (httpNodeRoot), or
    // the static content (httpStatic), the following properties can be used.
    // The pass field is a bcrypt hash of the password.
    // See http://nodered.org/docs/security.html#generating-the-password-hash
    //httpNodeAuth: {user:"user",pass:"$2a$08$zZWtXTja0fB1pzD4sHCMyOCMYz2Z6dNbM6tl8sJogENOMcxWV9DN."},
    //httpStaticAuth: {user:"user",pass:"$2a$08$zZWtXTja0fB1pzD4sHCMyOCMYz2Z6dNbM6tl8sJogENOMcxWV9DN."},
    // The following property can be used to enable HTTPS
    // See http://nodejs.org/api/https.html#https_https_createserver_options_requestlistener
    // for details on its contents.
    // See the comment at the top of this file on how to load the `fs` module used by
    // this setting.
    //https: {
    //    key: fs.readFileSync('privatekey.pem'),
    //    cert: fs.readFileSync('certificate.pem')
    // The following property can be used to cause insecure HTTP connections to
    // be redirected to HTTPS.
    //requireHttps: true
    // The following property can be used to disable the editor. The admin API
    // is not affected by this option. To disable both the editor and the admin
    // API, use either the httpRoot or httpAdminRoot properties
    //disableEditor: false,
    // The following property can be used to configure cross-origin resource sharing
    // in the HTTP nodes.
    // See https://github.com/troygoode/node-cors#configuration-options for
    // details on its contents. The following is a basic permissive set of options:
    //httpNodeCors: {
    //    origin: "*",
    //    methods: "GET,PUT,POST,DELETE"
    // If you need to set an http proxy please set an environment variable
    // called http_proxy (or HTTP_PROXY) outside of Node-RED in the operating system.
    // For example - http_proxy=http://myproxy.com:8080
    // (Setting it here will have no effect)
    // You may also specify no_proxy (or NO_PROXY) to supply a comma separated
    // list of domains to not proxy, eg - no_proxy=.acme.co,.acme.co.uk
    // The following property can be used to add a custom middleware function
    // in front of all http in nodes. This allows custom authentication to be
    // applied to all http in nodes, or any other sort of common request processing.
    //httpNodeMiddleware: function(req,res,next) {
    //    // Handle/reject the request, or pass it on to the http in node by calling next();
    //    // Optionally skip our rawBodyParser by setting this to true;
    //    //req.skipRawBodyParser = true;
    //    next();
    // The following property can be used to verify websocket connection attempts.
    // This allows, for example, the HTTP request headers to be checked to ensure
    // they include valid authentication information.
    //webSocketNodeVerifyClient: function(info) {
    //    // 'info' has three properties:
    //    //   - origin : the value in the Origin header
    //    //   - req : the HTTP request
    //    //   - secure : true if req.connection.authorized or req.connection.encrypted is set
    //    // The function should return true if the connection should be accepted, false otherwise.
    //    // Alternatively, if this function is defined to accept a second argument, callback,
    //    // it can be used to verify the client asynchronously.
    //    // The callback takes three arguments:
    //    //   - result : boolean, whether to accept the connection or not
    //    //   - code : if result is false, the HTTP error status to return
    //    //   - reason: if result is false, the HTTP reason string to return
    // Anything in this hash is globally available to all functions.
    // It is accessed as context.global.
    // eg:
    //    functionGlobalContext: { os:require('os') }
    // can be accessed in a function block as:
    //    context.global.os
        // os:require('os'),
        // octalbonescript:require('octalbonescript'),
        // jfive:require("johnny-five"),
        // j5board:require("johnny-five").Board({repl:false})
    // The following property can be used to order the categories in the editor
    // palette. If a node's category is not in the list, the category will get
    // added to the end of the palette.
    // If not set, the following default order is used:
    //paletteCategories: ['subflows', 'input', 'output', 'function', 'social', 'mobile', 'storage', 'analysis', 'advanced'],
    // Configure the logging output
    logging: {
        // Only console logging is currently supported
        console: {
            // Level of logging to be recorded. Options are:
            // fatal - only those errors which make the application unusable should be recorded
            // error - record errors which are deemed fatal for a particular request + fatal errors
            // warn - record problems which are non fatal + errors + fatal errors
            // info - record information about the general running of the application + warn + error + fatal errors
            // debug - record information which is more verbose than info + info + warn + error + fatal errors
            // trace - record very detailed logging + debug + info + warn + error + fatal errors
            // off - turn off all logging (doesn't affect metrics or audit)
            level: "info",
            // Whether or not to include metric events in the log output
            metrics: false,
            // Whether or not to include audit events in the log output
            audit: false
//  2020 04 29  Added theme
editorTheme: {
    page: {
        css: "/home/me/.node-red/node_modules/@node-red-contrib-themes/midnight-red/theme.css"
I deleted a bit about passwords in the middle. Just so you don't say "there's a bit missing" or a bracket isn't complete.
Oh, and this is the directory....
The text you added in the settings.js file is not nested correctly. You need to move it up one level (above the last curly bracket). Then add a comma after the second last curly bracket to differentiate between the Logging block and the editorTheme block (what you added).
Ok, changed the end of the settings.js file and it now looks like:
    logging: {
        console: {
            level: "info",
            metrics: false,
            audit: false
    editorTheme: {
        page: {
Now when I start NR, I see this:
Starting as a systemd service.
Error loading settings file: /home/me/.node-red/settings.js
/home/me/.node-red/settings.js:248
    editorTheme: {
SyntaxError: Unexpected identifier
    at Module._compile (internal/modules/cjs/loader.js:723:23)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    at Module.load (internal/modules/cjs/loader.js:653:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    at Module.require (internal/modules/cjs/loader.js:692:17)
    at require (internal/modules/cjs/helpers.js:25:18)
    at Object.<anonymous> (/usr/lib/node_modules/node-red/red.js:119:20)
    at Module._compile (internal/modules/cjs/loader.js:778:30)
^C
I seem to be having a lot of bad luck.
For the sake of testing:
I make this the end of the file:
//    editorTheme: {
//        page: {
//            css: "/home/me/.node-red/node_modules/@node-red-contrib-themes/midnight-red/theme.css"
Node-red works quite happily.
SORRY!
Ok it works now.
Wow! Noice!
It saves a lot of electrons too, not needing to make the screen as white. :wink:
(ok, I won't give up my day job)
However, the original observation about the default layout still stands as mentioned.
I may not keep this, it is a bit too dark. I don't want to become a goth or emo.
You should try it. Goths are cool. (reference to one of the greatest sitcoms ever made)
Maybe. But it went straight over my head. I'm short. :wink:
Now you know how to add a CSS file and how to remove it, why not make a copy and try changing things? You now know that no harm can come since you just need to edit settings.js, restart Node-RED and refresh your browser tab.
Won't be long before you are picking up how things work.
I admire your confidence in my abilities......
But I am not that confident.
If I get bored, I may tweak the existing files (the new part I installed) but I am a long way from being that bored. I have a lot of other work pending.
You don't need to be confident :wink: You just need to try.
Well, you have the info for when you need it anyway. I sympathise with workload, I've had very little to no spare energy or brain cells for anything outside of work recently.
