Theme Don't change
Please help me urgently.
Something happened after importing an example from here on the forum.
My whole theme got messed up.
And I can't restore the screen to original mode.
Did I remove all the existing CSS to go back to the original nod-red dark theme (But even that doesn't work)?
Wonder what's going on?
Even selecting this theme nothing is changed. What could be happening?
Just to complement:
I exported my whole theme to another nod-red and it broke the other nod-red as well.
If I reset everything, delete all the flows, it still has this problem of not letting me change the theme.
What will be the problem?
after a lot of headbutting.
I found out that node-red has a bug. I needed to press F5 and reload the entire node-red so that it starts working again from scratch.
That isn't a bug, it just means that the browser had cached something and you had to tell the browser to reload everything from node red in order to recover.
For me it's a bug.
Do some things work and others not?
How can something the browser does, without involving node red, be a bug in node red?
https://geekflare.com/disable-cache-in-browsers/
I agree with you, but it makes me think of the way node-red pops up a message to let you know to restart the server after updating the pallette sometimes. Maybe a well placed alert can inform a user to do a hard refresh.
I know it was pretty confusing...
I really didn't understand why I put elements on the screen and they all worked... I took the elements away and they worked.
however: When I changed the theme it didn't work.
I lost two 2 hours and a lot of work until I found out that I just had to press F5 and update.
