There are no new node posts in Mastodon Node-RED Nodes
Hi @knolleary and @cymplecy(for knowledge) , there is a problem with a new posts @nodes@social.nodered.org Mastodon channel. I receive the news only from twitter.
For help, I have used a rss node with certificate expired error (expired 5/04/2023).
I don't know if it can help
Thank's a lot
The last one I see posted on Mastodon was https://fosstodon.org/@nodes@social.nodered.org/110143868806871750
(2 days ago)
What was the last one posted on twitter?
Hi @cymplecy, i have this post at 11.38 07/04/2023 (date and hour from send post to telegram)
node-red-contrib-home-assistant-websocket (0.49.1)
Node-RED integration with Home Assistant through websocket and REST API
flows.nodered.org
Looks like the ssl cert has failed to renew again... I won't be able to fix until tonight.
No problem, I don't understand the connection between the posts you publish on mastodon, with what I read from mastodon.
Should be fixed now. Looks like the ssl cert was renewed, but nginx wasn't restarted to pickup the new cert. Will need to dig into why that sometimes fails.
Yes, I have received the New post.
Thanks a lot and happy easter at alla.
