This is a new (weird) error
While optimising some flows, etc, I got this error:
FileError: 'http://192.168.0.99:1880/ui/css/app.min.less' wasn't found (0)
in app.min.less
Google isn't that helpful.
Anyone?
Try restarting node red and force a full refresh of the browser. If it still happens then more information is required I think.
Thanks.
But in the mean time, it has gone away.
I probably rebooted the machine and all started working again.
The post is old......
I have the same problem on a Tablet with android, just after to run node-red update.
Any comment or help?
Have you tried resetting the browser cache?
Yes but there were no changes
also try other browsers (opera mini, Chrome, etc) and shows the same error :frowning:
Then please try restarting Node-RED and posting the startup log here
This is the log
My node-red run on raspberrypi B 3
pi@raspberrypi:~ $ node-red-start
Start Node-RED
Once Node-RED has started, point a browser at xxxxxxxxxxx:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-start to start Node-RED again
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to :flows.nodered.org
Starting as a systemd service.
30 May 14:26:04 - [info]
Welcome to Node-RED
30 May 14:26:04 - [info] Node-RED version: v0.20.5
30 May 14:26:04 - [info] Node.js version: v8.11.1
30 May 14:26:04 - [info] Linux 4.19.42-v7+ arm LE
30 May 14:26:07 - [info] Palette editor disabled : npm version too old. Requires npm >= 3.x
30 May 14:26:07 - [info] Loading palette nodes
Thu, 30 May 2019 17:26:12 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
In the future, you will have to enable it yourself.
See github.com/yagop/node-telegram-bot-api/issues/319. at module.js:652:30
30 May 14:26:18 - [info] Dashboard version 2.14.0 started at /ui
30 May 14:26:19 - [info] Settings file : /home/pi/.node-red/settings.js
30 May 14:26:19 - [info] Context store : 'default' [module=memory]
30 May 14:26:19 - [info] User directory : /home/pi/.node-red
30 May 14:26:19 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
30 May 14:26:19 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
30 May 14:26:19 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
30 May 14:26:19 - [info] Starting flows
WF2
AC: :
WF2
AC: :
WF2
AC: :
30 May 14:26:30 - [info] Started flows
30 May 14:26:31 - [error] serial port /dev/rfcomm2 error: Error: Error: No such file or directory, cannot open /dev/rfcomm2
30 May 14:26:31 - [info] serial port /dev/ttyACM0 opened at 9600 baud 8N1
30 May 14:26:31 - [info] serial port /dev/ttyUSB0 opened at 9600 baud 8N1
30 May 14:26:31 - [error] [function:Output Filter: Temperatura] SyntaxError: Unexpected token u in JSON at position 1
30 May 14:26:31 - [error] [function:Output Filter: Humedad] SyntaxError: Unexpected token u in JSON at position 1
30 May 14:26:31 - [info] [mqtt-broker:61e2e87f.71cd08] Connected to broker: mqtt://localhost:1883
So how did you update node-RED?
As this is on a raspberry pi did you use the upgrade script as suggested in the raspberry pi age in the docs?
If not try running the script which should fix some of the issues in the logs.
