Timepicker-ui example
i woudl like use timekeeper-ui i found on github, seem nice but i'm not so expert for implemetation.
https://github.com/pglejzer/timepicker-ui
I have installed it with NPM , but unfortunatly example link is broken.
Can someone help to make implementation on template node ?
thank
There are options available already without introducing external libs.
example: Found a couple of really cool simple time pickers - #4 by Steve-Mcl
example: Date range picker - #6 by Steve-Mcl
Do you really need THAT particular library?
Also, is about the depreciated node-red-dashboard OR newer @flowfuse/node-red-dashboard?
Honestly no, but see nice have mobile style interface on all browser.
Even it may look nice the reason it is not created as some (default)widget for desktop browser is that humans are good enough with hand or finger but not that good with a mouse in that same hand. Circular motion it requires must be done quite perfectly to get the results constantly. But in average the failure rate is too high.
That's it. No more. Every one is of course free to do it and you can find examples from codepen....
