UI for timekeeper Android style
i have done this timekeeper starting from github code, the strange thing is some time is working and sometime not, the field are displayed but the editing not. not every time, seem not realted to the browser, but making deploy more time in same case start to run. I'm not so expert in code, can anyone check if there is any concept error in html / javascript ?
thank in advance.
r.
        "id": "5b205c9414353ac5",
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": "",
        "env": []
        "id": "ae119afba03b35d4",
        "type": "debug",
        "z": "5b205c9414353ac5",
        "name": "debug 87",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 720,
        "y": 220,
        "id": "897358a91fa3edc3",
        "type": "ui_template",
        "group": "e89b87ae89095b54",
        "name": "mytimepicker",
        "order": 1,
        "width": "8",
        "height": "8",
        "format": "<html>\n<script type=\"text/javascript\">\n    $(document).ready(function() {\n    $('.standard').clockTimePicker();\n});\n</script>\n<script src=\"https://code.jquery.com/jquery-3.6.0.min.js\"></script>\n<script src=\"https://unpkg.com/jquery-clock-timepicker@2.2.0/jquery-clock-timepicker.min.js\"></script>\n\n<style type=\"text/css\">\n    .main {\n        text-align: center;\n    }\n    .time {\n        display: flex;\n        font-size: 18px;\n        padding: 5px;\n        text-align: center;\n        width: 94px;\n        margin-top: 5px;\n    }\n</style>\n<style type=\"text/css\">\n    .clock-timepicker input {\n        caret-color: transparent;\n    }\n</style>\n\n<body>\n    <div class=\"main\">\n        <div class=\"clock-timepicker\" style=\"display:inline-block; position:relative\"><input class=\"time standard\" type=\"text\" value=\"10:15\" onchange=\"console.log('Time changed to: ' + this.value)\"  style=\"min-width: 94px;\" autocomplete=\"off\" autocapitalize=\"none\" spellcheck=\"false\">\n            <div class=\"clock-timepicker-autosize\"\n                style=\"position: absolute; opacity: 0; display: none; top: 5px; left: 0px; font-size: 26px; font-family: MS Shell Dlg \\32 ; font-weight: 400; line-height: normal;\">\n                10</div>\n            <div class=\"clock-timepicker-popup\"\n                style=\"display: none; z-index: 99999; cursor: default; position: fixed; width: 200px; background-color: rgb(255, 255, 255); box-shadow: rgba(0, 0, 0, 0.14) 0px 4px 20px 0px; border-radius: 5px; overflow: hidden; user-select: none; visibility: visible; left: 799px; top: 366.4px;\">\n                <div style=\"position: relative; width: 180px; height: 180px; margin: 10px;\"><canvas\n                        class=\"clock-timepicker-hour-canvas\"\n                        style=\"cursor: default; position: absolute; top: 0px; left: 0px; zoom: 100%; display: block; opacity: 1; z-index: 1;\"\n                        width=\"180\" height=\"180\"></canvas><canvas class=\"clock-timepicker-minute-canvas\"\n                        style=\"cursor: default; position: absolute; top: 0px; left: 0px; display: block; zoom: 100%; opacity: 1; z-index: 1;\"\n                        width=\"180\" height=\"180\"></canvas></div>\n            </div>\n        </div>\n    </div>\n\n</body>\n\n<script>\n    (function(scope) {\n        scope.$watch('msg', function(msg) {\n            if (msg) {\n                $('  .clock-timepicker input').clockTimePicker('value', '08:00');\n            }\n        });\n\n\n    })(scope);\n</script>\n\n\n</html>",
        "storeOutMessages": true,
        "fwdInMessages": false,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 490,
        "y": 220,
                "ae119afba03b35d4"
        "id": "e1fa1948696528c8",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 240,
        "y": 220,
                "897358a91fa3edc3",
                "a9f4f8b42930fdc4"
        "id": "a9f4f8b42930fdc4",
        "d": true,
        "order": 1,
        "width": "8",
        "height": "8",
        "format": "<html>\n\n<script type=\"text/javascript\">\n    $(document).ready(function() {\n    $('.standard').clockTimePicker();\n});\n</script>\n<script src=\"https://code.jquery.com/jquery-3.6.0.min.js\"></script>\n<script src=\"https://unpkg.com/jquery-clock-timepicker@2.2.0/jquery-clock-timepicker.min.js\"></script>\n\n<style type=\"text/css\">\n    .main {\n        text-align: center;\n    }\n    .time {\n        display: flex;\n        font-size: 18px;\n        padding: 5px;\n        text-align: center;\n        width: 94px;\n        margin-top: 5px;\n    }\n</style>\n<style type=\"text/css\">\n    .clock-timepicker input {\n        caret-color: transparent;\n    }\n</style>\n\n<body>\n    <div class=\"main\">\n        <div class=\"clock-timepicker\" style=\"display:inline-block; position:relative\"><input class=\"time standard\" type=\"text\" value=\"10:15\" onchange=\"console.log('Time changed to: ' + this.value)\"  style=\"min-width: 94px;\" autocomplete=\"off\" autocapitalize=\"none\" spellcheck=\"false\">\n            <div class=\"clock-timepicker-autosize\"\n                style=\"position: absolute; opacity: 0; display: none; top: 5px; left: 0px; font-size: 26px; font-family: MS Shell Dlg \\32 ; font-weight: 400; line-height: normal;\">\n                10</div>\n            <div class=\"clock-timepicker-popup\"\n                style=\"display: none; z-index: 99999; cursor: default; position: fixed; width: 200px; background-color: rgb(255, 255, 255); box-shadow: rgba(0, 0, 0, 0.14) 0px 4px 20px 0px; border-radius: 5px; overflow: hidden; user-select: none; visibility: visible; left: 799px; top: 366.4px;\">\n                <div style=\"position: relative; width: 180px; height: 180px; margin: 10px;\"><canvas\n                        class=\"clock-timepicker-hour-canvas\"\n                        style=\"cursor: default; position: absolute; top: 0px; left: 0px; zoom: 100%; display: block; opacity: 1; z-index: 1;\"\n                        width=\"180\" height=\"180\"></canvas><canvas class=\"clock-timepicker-minute-canvas\"\n                        style=\"cursor: default; position: absolute; top: 0px; left: 0px; display: block; zoom: 100%; opacity: 1; z-index: 1;\"\n                        width=\"180\" height=\"180\"></canvas></div>\n            </div>\n        </div>\n    </div>\n\n</body>\n\n<script>\n    (function(scope) {\n        scope.$watch('msg', function(msg) {\n            if (msg) {\n                $('  .clock-timepicker input').clockTimePicker('value', '08:00');\n            }\n        });\n\n\n    })(scope);\n</script>\n\n\n</html>",
        "className": "",
        "x": 490,
        "y": 120,
                "ae119afba03b35d4"
        "id": "e89b87ae89095b54",
        "type": "ui_group",
        "name": "Clock",
        "tab": "debd57ea971062c2",
        "order": 1,
        "disp": true,
        "width": "10",
        "collapse": false,
        "className": ""
        "id": "debd57ea971062c2",
        "type": "ui_tab",
        "name": "Animated clock",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
What are you trying to accomplish?
What do you mean by 'Android style'? (I don't have an Android device)
If you are looking to have a clock on the dashboard have you looked at
node-red-contrib-ui-digital-clock
node-red-contrib-ui-digital-display
@zenofmud are these DB2 nodes?
No, they are db1 nodes
I mean these style, but most of the time there is only the text field, not the round clock.
immagine
here is a link to a thread (FROM 2021) where @hotNipi created a clock and (other things) using the quake node. This might give you a starting point. It is a long thread but full of information. If you scroll down to entry 94 or 95 you will see a demo flow you can play with.
With the time input nodes I think it is up to the browser how it shows it.
This is pretty interesting thing.
@hotNipi - Nice find
Drats, I just noticed I didn’t add the link and spell check messed up the name of the node (head slap)
Here is the link for the ā€˜gauge’ node
