TRIGGER node -- bug report
Just found another bug with the trigger node.
Details of my setup:
NR 1.0.3
Dashboard 2.19.4
O/S Ubuntu 18.4 LTS
By default the node is in the wait for mode.
If you change it to wait to be reset and deploy the node: you can't change the mode of the node.
I've tried several times now.
You get the gui when you open the node and can select the other mode/s but when you deploy it remain saying trigger & block.
I can reproduce as well.
When I add a new node, change the trigger mode and deploy, the mode of the trigger will change, but the text remains "trigger & block"
Will fix. - Workaround - When you switch mode away from wait for reset - you also need to set the time to a value other than 0.
