Trouble when install or update node
Morning,
Since few days i've an error message when i try to install or update node.
Error message is:
npm WARN config production Use --omit=dev instead.
npm WARN old lockfile
npm WARN old lockfile The package-lock.json file was created with an old version of npm,
npm WARN old lockfile so supplemental metadata must be fetched from the registry.
npm WARN old lockfile This is a one-time fix-up, please be patient...
npm ERR! code EBADENGINE
npm ERR! engine Unsupported engine
npm ERR! engine Not compatible with your version of node/npm: follow@0.12.1
npm ERR! notsup Not compatible with your version of node/npm: follow@0.12.1
npm ERR! notsup Required: {"node":"0.12.x || 0.10.x || 0.8.x"}
npm ERR! notsup Actual: {"npm":"9.6.4","node":"v16.20.0"}
npm ERR! A complete log of this run can be found in: C:\Users\NICOLAS\AppData\Local\npm-cache_logs\2023-05-22T10_10_44_788Z-debug-0.log
I try to downgrade node and npm but i've always got the same trouble.
I've you got an idea to fix it.
Nico
Something you have installed includes a dependency on follow@0.12.1 - which is a very out of date and doesn't support the version of node.js you are using.
The follow module appears related to CouchDB - does that give you any clues as to what you've installed that is pulling in this old dependency?
You could also run npm list follow in your .node-red directory to see what module is pulling it in.
Once you've figured that out, you'll need to see if there is a newer version of the module available, or look for an alternative.
Please let us know what you find.
Hello Nick,
I followed your instructions and launched npm list follow, you think right it's CouchDB but there was also an oracle module.
I deleted the 2 and now it's ok.
Thank you very much for your help.
Best Regards
Nico
I also take this opportunity to congratulate you and thank you for the development of this great tool that is node-red.
