We just upgraded our Node.js from v12 to v14.
NodeRED version is 1.0.4
After the upgrade we get:
The node node-red-contrib-ttn shows :
Doesn't seem to be able to be either removed or upgraded.
Any suggestions maybe on this issue?
it may need rebuilding ...
cd ~/.node-red
npm rebuild
or it just may not be supported under node 14
Already tried a rebuild, no luck. So it's probably not supported
What do you see if you run, in the .node-red folder
npm install node-red-contrib-ttn
Ok, we performed the rebuild from the NodeRED subdirectory, in stead of the root. Now all seems to be working fine!
Thanks all!
